12-09-2017, 09:01 PM | #1 |
Drives: 2015 camaro rs Join Date: Jan 2016
Tire Noise
I have to turn the volume on my up on my radio so loud to hear it over the road noise that it hurts my wife,s ears.Has anyone found a way to tune down the noise?
12-09-2017, 09:34 PM | #2 |
Banned
Drives: Camaro Join Date: Mar 2013
Put a gag in her mouth.
12-09-2017, 09:41 PM | #3 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
/thread
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
12-10-2017, 06:02 PM | #4 |
sound deadenr in the spare tire area... the trunk is a metal resonating chamber... Buy some cheap noico sound deadener from Amazon...
Take the back seat and rear plastic off... The hips of this car are bare metal, not much insulation. You can easily decrease road noise by 3db... If not 6db. Just by deadening the rear of the car.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
12-11-2017, 10:25 AM | #5 |
Thanks for the sarcasm,and insult to my wife, dickweeds like should ride a bus>
12-11-2017, 10:33 AM | #6 |
Thanks for your ideas,except for the bus rider,I thought that S**t like belonged in the lounge.
01-06-2018, 09:21 PM | #7 |
Drives: 2015 Camaro 1SS 6M Join Date: Dec 2017
Which tires are you using, and how is the wear pattern on them? Different tire models produce vastly different amounts of noise, if there is a weird wear pattern such as feathering that could add to the volume as well.
The only other tip I have is to ensure your doors and trunk seal well, you can check for seal tension with a dollar bill or by trying to blow smoke around the gaps. Any gap/misalignment of the seal seating areas can produce wind noise at speed. |
