12-05-2019, 09:06 PM | #1 |
Drives: 2013 LS3 Camaro Join Date: Jul 2017
Fuel Pressure
I keep seeing different answers.
What is the stock fuel pressure for m6? |
12-05-2019, 09:21 PM | #2 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
Manual or automatic doesn't matter. I don't know specifically, but I would expect to see around 60psi or so. I'm sure someone can post the actual spec though.
12-05-2019, 11:18 PM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
58
12-06-2019, 10:18 AM | #4 |
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
60ish, +/-
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
12-06-2019, 11:14 AM | #5 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
58 is what mine runs at also. But I do have the ZL1 fuel pump.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
12-06-2019, 01:22 PM | #6 |
factory fuel pressure runs about 58psi, but is commanded to drop to 50-51psi in the upper RPM. most people believe that this is caused by the pump getting weak but in most cases that is not true. it is in the GM programming of the fuel pump control module.
give us a shout at Support@Gwatneyperformance.com if you ever need any more answeres. we would be glad to help. Ben Weishaar |
12-06-2019, 01:50 PM | #7 |
4 bar - 58psi
12-06-2019, 08:18 PM | #8 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Stupid question but this seems a somewhat relevant place to ask it. If stock as is ~58, what is the pressure on the ZL1 pump? Or is it the same pressure and is just capable of moving a lot more fuel at that same pressure?
And does this mean that when injector shopping, I should be looking at the rating of the injectors at 4 bar? Seems like most list them based off the 3 bar flow
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
12-10-2019, 06:58 PM | #9 | |
Injectors that are rated 50lb/hr @ 43psi will flow more fuel at 58psi than injectors that are rated 50lb/hr @ 58psi. So, keep looking at the 3 bar flow ratings |
12-11-2019, 05:52 AM | #10 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
ZL1 fuel pressure is 58psi at all times. If you drop a ZL1 pump into a stock SS, you will get 58psi tapering down to 48psi by redline (but slightly more flow from the bigger pump). If you add a ZL1 FPCM, you will get 58psi at all times. If you use HPTuners to edit your stock ss FPCM, you can set it to whatever you want. That's why you see so many different answers on this topic. The FPCM (fuel pump control module) controls the fuel pressure.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
12-11-2019, 08:50 AM | #11 | ||
Makes sense. If I am reading right, the ZL1 FPCM isn't really needed, now that you can use HPT to make these changes to the SS one? Related question: could one get slightly more flow out of an SS pump by just commanding it to 58 at all times instead of dropping off? Not that I plan to do so, just curious while we are near the subject Thank you guys for the answers though!
12-11-2019, 03:37 PM | #12 | |||
Could be either way, just need to verify with seller. Quote:
