04-11-2019, 12:36 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2017
Holley Fuel Rail Question
Has anybody installed the holley fuel rails using stock injectors? I'm having a time getting the orings to fit and seal properly. I FINALLY found the correct oring for the bottom. (Bosch 3-100). I installed the rails and primed the motor, now the top is leaking. I'm still using the stock orings on the top side and just ordered (Bosch 3-108) hoping they will work. Does anybody have a solution?
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
04-11-2019, 12:38 PM | #2 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Sorry I do not have a solution, but I just put the fuel rails on my intake with stock injectors. I did not have to change a thing. The only thing that leaked was the tee fitting I used to hook the rails together. And that was because I didn't tighten it enough. I used stock orings and all, haven't had a problem. Maybe the rails were a bad batch?
04-11-2019, 12:55 PM | #3 |
well I switched up my manifold too.. just need to figure out whats up with the top.
04-11-2019, 01:02 PM | #4 |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
Long shot... what manifold are you running? I assume it didn't require fuel rail spacers for running stock injectors. If you have fuel rail spacers, maybe they are too big preventing the injectors from seating all the way.
04-11-2019, 01:11 PM | #5 |
Low profile Holley sniper. I don't think I need spacers. It fits nice and snug. And only 3 of the 8 injectors were wet with fuel
04-11-2019, 04:20 PM | #6 |
Drives: 2015 1LE Join Date: Oct 2015
I used my stock injectors in those rails with no leaks in a stock manifold. I want to say the orings were blue,.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
04-11-2019, 05:27 PM | #7 |
The factory manifold Holley rails are different than the rails that come with the Sniper manifold.
04-11-2019, 07:45 PM | #8 |
aghhhhh good to know!
04-12-2019, 05:30 AM | #9 | |
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator |
04-12-2019, 11:13 AM | #10 |
Went to O Rielly's yesterday and picked up a set of injector orings in the performance section, now we are leak free! I just needed something a little thicker!
04-12-2019, 11:45 AM | #11 |
Thread Tools | |
