11-03-2013, 01:42 PM | #1 |
Rawr!
Drives: Giulia Quadrifoglio, C8 Stingray Join Date: Sep 2013
well. i failed. any way to salvage this?
yeah, i was washing my car, and there were all this white dots stuck on the paint. i tried to remove it with the green side of a sponge.
failed big time. so... how do i fix this? http://i982.photobucket.com/albums/a...ps92976dfc.jpg this stuff is all over my car.
Current:
2023 Red Mist Corvette Stingray 2LT 2021 Trofeo White Alfa Romeo Giulia Quadrifoglio Retired: 2018 Garnet Red Camaro 2SS 2014 Crystal Red Camaro RS |
11-03-2013, 01:46 PM | #2 |
Drives: 2015 Mustang GT Join Date: Mar 2012
Uhh... youll need to have it compounded then finished over with a fine polish
What you did was "marr" the surface. You used something that was to abrasive to wash a car with, and you applied to much pressure. I fix this all the time for cars that I detail. A good full detail should run you a bit over $500. |
11-03-2013, 01:53 PM | #3 | |
Rawr!
Current:
11-03-2013, 01:54 PM | #4 |
11-03-2013, 01:55 PM | #5 |
Lol no. Don't panic, his price is way off to fix this.
It needs to be compounded and polished as he mentioned. To fix that spot should cost you $50. A detailer should jump at the chance to fix that because he will make a customer for life. If you want to go the DIY route, send me a message I can get you set up. Sent from my HTC One using Tapatalk 2
[B]
11-03-2013, 01:56 PM | #6 | |
I'm assuming he washed his entire car like that. No detailer in their right mind would correct a camaro for $50. But yes, if he just wanted 1 spot in a 2'x2' area fixed, and no other services, $50 isn't bad. But then he'd have 1 perfect spot on his car and the rest in whatever condition it was in when it arrived. |
11-03-2013, 01:56 PM | #7 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
You need a proper machine paint correction. A HEAVY one! You basically wet sanded your car lol
This is going to cost you $600-900 depending on how much there is. Did you do this to the entire car? You're not too far from me. I do a detail job once and a while on the side, I have no overhead so my prices are lower than what you'll likely find. I can definitely fix this for you. Feel free to send me a PM. |
11-03-2013, 01:58 PM | #8 | |
[B]
11-03-2013, 01:59 PM | #9 | |
When it comes to enthusiast cars, people have no problem paying to have them setup well. I've done details where I've charged $1500. Spot sanding, three stage polish, coatings, metal polishing, wheel coating, caliper coatings, you name it. |
11-03-2013, 02:00 PM | #10 | |
[B]
11-03-2013, 02:03 PM | #11 | |
and I said above, you're undervaluing yourself. |
11-03-2013, 02:05 PM | #12 | |
OP I can also take care of those white spots assuming its not some defect in the finish from the factory. I'll also throw in a free detail clinic. Something like this won't happen again and you'll leave knowing 100X more than you'd probably imagine. Thanks! This would be the easiest job I've done in recent memory. |
11-03-2013, 02:07 PM | #13 | |
In any case, I don't do detailing as my job anymore, just a hobby and the occasional said job. So the point is moot. Sent from my HTC One using Tapatalk 2
[B]
11-03-2013, 02:17 PM | #14 | |
