06-04-2018, 06:42 PM | #1 |
El Duderino
SOLD 2010-2011 Camaro Chassis Max Brace (Fits SS LT LS RS Vert)
Hotchkis Sport Suspension 20104 2010-2011 Camaro Chassis Max Brace.
Like most modern muscle cars the new 2010 Camaro suffers from significant chassis flex and wheel hop. Under hard acceleration the stock rear subframe moves quite a bit reducing traction and stability. Installing a Hotchkis Sport Suspension Chassis Max Brace reduces chassis flex and improves traction during hard launches and high-speed cornering by triangulating the rear sub frame to the chassis frame rails. https://www.hotchkis.net/product/201...k=&yr=&md=&sm= Installation Guide: http://files.hotchkis.net/instructions/20104.pdf Used - great condition. $285 Shipped CONUS. If this post is up, it's still available.
I bowl. Drive around. The occasional acid flashback.
06-04-2018, 07:42 PM | #2 |
Drives: 2018 ZLE Join Date: Jul 2014
hmm tempting
06-04-2018, 07:53 PM | #3 |
El Duderino
I don't now a lot about wheel hop, but after removing springs, sway bars and end-links, I still had the brace on. I think it helps quite a bit with body roll...
The 6 banger vert (slightly heavier than an SS Coupe) already has extra body bracing, but this did make a big difference IMHO.
06-06-2018, 07:32 PM | #4 |
El Duderino
Pending
