Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 05-27-2020, 07:06 PM   #1
Hoos68
Drives: 1968 Camaro
2psd Pwr Glide vs 350Turbo
Have a 68 Camaro - was straight 6 - dropped 454 in her. 2 speed powerglide is shot - only runs in low. Should i rebuild it or get 350TH turbo?
Hoos68 is offline   Reply With Quote
Old 05-27-2020, 07:20 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
I'd only use the PG if it is a track car.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 05-30-2020, 01:09 AM   #3
ariZona28
ariZona28's Avatar
None of the above. Big boy engine calls out for big boy transmission. Go with a built TH400 with approx 3500 RPM stall and prevent future anguish. Throw in a 3.73 Moser 12-bolt or 9in rear to reduce the chance of a rearview mirror full of parts. Caution: this combination may lead to a reduction in rear tire longevity.
ariZona28 is offline   Reply With Quote
Old 05-30-2020, 04:33 PM   #4
Zspoiler
Zspoiler
Drives: 1979 Z-28 RS Camaro
I would also run a Turbo 400 with a minimum 3;73 gears .With a 8.5 10 bolt.12 bolt and or Ford 9' inch as selections
Zspoiler is offline   Reply With Quote
2 speed powerglide, transmission change
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
