06-29-2020, 12:51 PM | #1 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
What "WAX" would you recommend?
Within the last month I purchased two sets of 2014-2015 SS wheels, both set were painted. I had my powder coater give them a "make over". The color of the powder is called "Black Sapphire Too". High gloss and once in the sun light you can see a trace of the sapphire sparkle. Love the color. Center caps are OEM gloss black caps.
This morning I applied a coat of wax, both front and rear. Got thinking as to what would be the best wax or coating to use on the beautiful wheels? Teach me something new please! Larry
06-29-2020, 05:58 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
I'm not a detailing pro but I like Silver Wax's sealant; it's a sealant rather than a wax (basically a more durable wax, lasts much longer), and then you can apply your typical synthetic or natural wax on top of it (and then spray wax on top of that if you're so inclined). The sealant seems to work quite well and I get water beading off the paint even after 6 months (no waxing of any kind during those following 6 months - works great!). FYI you can also use the sealant on your windshield - it's like RainX on roids!
06-29-2020, 07:00 PM | #3 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Ceramic coating would be a great choice. You can get a kit from amazon for like $40 and do your whole car and rims with it.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
06-29-2020, 08:57 PM | #4 | |
06-29-2020, 08:59 PM | #5 | |
I love shiny wheels!
06-30-2020, 05:31 AM | #6 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Here is another vote for having them CERAMIC COATED. I have had this done to the last 3 cars I have owned and it makes so much of a difference….it makes them sooooooooooo easy to clean!
06-30-2020, 06:15 PM | #7 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Go to Custom Offsets, they carry a line of wheel and tire cleaner that I swear by.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
