10-06-2020, 08:24 AM | #1 |
Drives: 2014 Camaro 2SS Manual Join Date: Feb 2018
2014 SS manual Driveshaft issues.
Hi Everyone! I recently purchased a Driveshaft Shop 3.5 Aluminum drive shaft for a 2014 SS LS3 manual. The only modifications that I have so far are an Eaton tru-track diff and 4.10 gears installed in the stock housing. The issue is the length of the driveshaft was not correct! From what I was told by the Driveshaft Shop the correct flange to flange measurement should be 561/8" but mine is measuring at 553/8" using the stock transmission and pinion flanges. Has anyone else had this issues? Also it would be really useful if anyone else can post their measurement for the same year and make. I am curious if there is something strange with mine.
Thanks! Diff: Flange to flange measurement: Last edited by Shtiggs; 10-06-2020 at 09:29 AM. Reason: add pics |
10-06-2020, 10:14 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
I'm replacing my driveshaft this weekend and can take a measurement for comparison.
10-06-2020, 11:14 AM | #4 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
The only time I measured is when I installed it and follow the directions
Mine was right at 3.25 And i havent had a issue as of yet Keeping my fingers crossed |
10-06-2020, 11:36 AM | #5 | |
You have better luck than me my friend! |
10-06-2020, 12:18 PM | #6 | |
Sorry bro |
10-07-2020, 06:54 PM | #7 |
Drives: 2010 ss Join Date: Oct 2015
I had the same problem,wrong length.i sent it back,they fixed it,guys were jack asses about it,put it back on.140 to 150 shook like crazy,pulled the piece of shit off and sold it.problem solved.not happy about it.they tryed saying the vendor was at fault.wtf they can kiss my ass
10-08-2020, 10:32 AM | #8 | |
What really sucks is that I have to pay shipping so this is really going to end up costing me... Last edited by Shtiggs; 10-08-2020 at 04:09 PM. |
10-09-2020, 09:49 AM | #9 |
start digging around they sent out many that were to long,guess the guy that cut them doesnt use a tape measure is what i think,worst thing about it they dont own up to the problem
10-10-2020, 11:59 AM | #10 |
Mine also measured at 55-3/8"
Sent from my Pixel XL using Tapatalk
10-12-2020, 09:55 AM | #11 |
Thanks for the measurement @larry_g. It really does get under my skin that I have to end up paying more in shipping for them to correct a manufacturing defect.
11-17-2020, 06:48 PM | #12 |
I am really starting to regret going with the DSS shaft. I just got it back yesterday from them shorting it. Everything went smooth on the installation but now I have extreme vibration between 120 and 140. I will be rotating it tomorrow as they stated to do, to see if the speed range of the vibration changes or if it is resonating through the shaft. Seems too hard of vibrations to be resonance though.
11-17-2020, 06:53 PM | #13 |
11-18-2020, 09:44 AM | #14 |
I am also going to get my tires rotated and road force balanced to see if the issue is there. I think that I should be feeling vibrations earlier if it was caused by the shaft. I could use some feedback on other possible issues if rotating the shaft, and tire work does not solve the issue. Last thing I want is damage from vibration resonance to the transmission.
