07-11-2020, 05:57 PM | #1 |
What direction to go?
2010 SS
Have FE4 Upgrade along with BMR front/rear sway bars, LCAs, Detroit speed end links, and car is on air via Airlift 3P system. Question is what do I do next? Figured BMR toe/trailing and maybe some bushings around? Sub frame connectors or tunnel brace? Weekend mountain cruiser and occasional road track car. Sent from my iPhone using Tapatalk
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
07-11-2020, 10:07 PM | #2 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Rear cradle bushings.
Orange Krush II
07-12-2020, 03:04 AM | #3 |
I know the answer will always be solid, but what about BMR poly ones? Sent from my iPhone using Tapatalk
07-12-2020, 09:49 AM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I've had BMR cradle bushings and diff bushing for a week now and really love them. Huge improvement over stock.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
07-12-2020, 10:01 AM | #5 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
07-12-2020, 11:25 AM | #6 |
Depends on if you are going to keep the car long term I think. I’ve had my car sine early 10 an I went solids because while polys are better than the voided rubber bushings but they still give an still cause some cradle movement. If keeping long term find a set of solid aluminum or Delrin they don’t cause any unwanted noise or vibration.
Orange Krush II
07-12-2020, 04:15 PM | #7 |
8.60 @ 157 @ 4200lbs
Bmr
Bmr poly. Years and years running their products and time slips to prove their product along with daily street
2010 camaro twin turbo 8.60 @ 157 full weight 4200
07-12-2020, 07:20 PM | #8 |
Drives: 2011 Camaro 2LT Join Date: Oct 2018
Definitely cradle bushings. I just did them (Whiteline poly) and did z28 upper rear control arms while cradle was lowered. Big improvement. My plug for z28 UCAs.
07-12-2020, 07:25 PM | #9 |
Thanks all! I think there are some for sale in for sale as well. Ill go with cradle bushings and look at z28 LCAs
07-13-2020, 12:39 AM | #10 |
Upper control arm rear bushings not LCAs big difference.
Orange Krush II
07-14-2020, 03:35 PM | #11 |
Whoops thats what I meant! Any links to ones you recommend for solid? Sent from my iPhone using Tapatalk
07-14-2020, 08:24 PM | #12 |
Here’s a couple
https://afepower.com/afe-power-450-4...rame-mount-set http://w.ivenue.com/hendrixengineeri...-bushings.html https://www.detroitspeed.com/2010-15...-camaro-041510 Can’t go wrong with any of them just depending on your wallet and brand loyalty, I have a older set of the PAFDT/AFE bushings and completely satisfied with them, the DSE kit actually are actually threaded, the Hendrix kit is the Pegasus design from years ago before they went out of business.
Orange Krush II
08-01-2020, 07:32 PM | #13 | |
Thanks! Leaning towards the Hendrix at $399 special currently. But do like the idea of the Detroit Speed ones being threaded. But any added benefit there? Sent from my iPhone using Tapatalk
08-01-2020, 07:34 PM | #14 | |
Where did you get the z28 UCAs? Sent from my iPhone using Tapatalk
