Old 01-24-2018, 02:51 PM   #1
avido
Drives: camaro ss\rs
Wheel spacers
Guys, i was looking at the car and i started thinkig about a pair of spacers, to give the car a better look. I was wondering if someone used it and what size to buy. is 20mm too much?
2014 camaro SS Whipple powered ,3.750 pulley,ID850, CAI,Flowmaster American Thunder exhaust,MGW racing shifter,Bo White ported tb,MightyMouse Catch Can,Vitesse throttle controller,GM 3.91 rear end, Dynatech longtube haders, BTR Pd cam,Fluidampr stock pulley,ZL1 fuel pump and ADM fpcm, Phastek scoop and fluid thank relocation Bmr Motor mount . Tuned by Mastuning
avido is offline   Reply With Quote
Old 01-24-2018, 03:21 PM   #2
mantarey
mantarey's Avatar
Drives: 77corvette/2011blkcamaro
Not sure how thick 20mm is but I have 1/4 on my car
mantarey is offline   Reply With Quote
Old 01-24-2018, 03:21 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I have been using the H&R Trak+ DRM 30mm 6075670 on all 4 corners for about a year now. Pushed the stock rims out nicely and IMHO improved handling some....left them on when I went drag racin too! good luck!
Old 01-24-2018, 03:41 PM   #4
avido
thanks. i was looking for these
Hr 4075670
In italy, where i leave, if the wheels are out more than the body you risk the impound
Old 01-24-2018, 06:03 PM   #5
bowtiesonly
bowtiesonly's Avatar
Drives: 2012 Camaro 2ss
I use 1/4 aluminum spacers, had them for five years and have worked great, pushed wheels just about flush with body.
2012 2ss , long tube headers , summit x pipe ,borla mufflers, vararam intake, vmax ported throttle body rdp motorsports dynosteve tuned, BMR trailing arms and bushings elite engineering catch can. [Ifirst camaro ]2012 LT LFX, nytrex wet system ,GPI dyno tune, Injen longtube intake, Dynomax axle back exhaust, Vmax ported throttle body, elite engineering catch can.
bowtiesonly is offline   Reply With Quote
Old 01-25-2018, 02:05 PM   #6
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Wheel spacers are good just as long as you get some that are hub centric to your vehicle and also hub centric to the wheels you are installing, at that point is the best possible fitment you can have using a spacer.
Carlos_MRRWheelsInc is offline   Reply With Quote
