03-30-2023, 06:23 PM | #1 |
Drives: Camaro SS 2014 Join Date: Apr 2021
swapped car seat covers to katzkin airbag light on
I took the car to a local upholstery shop and they swapped the cloth seat covers for katzkin leather and now the airbag light is on. Will be taking it back to the same shop for further diagnostic.
Help where to start? Should I be looking for a Loose connector? Is it a 2014 SS convertible Last edited by claudiel19; 03-31-2023 at 07:24 AM. |
03-30-2023, 09:27 PM | #2 |
Drives: 2012 SS Join Date: Dec 2021
yes, look for an unplugged or loose connector.
2012 Camaro SS
03-31-2023, 09:43 AM | #3 |
Mine did that when we swapped to the Katzkins, all the connections were good. I had to take it back to my Chevy dealership and have the airbags "reset" and then it was all good!!
04-03-2023, 07:04 AM | #4 |
Thanks my friend! I will check the connections today if I find nothing then I’ll take it to the stealership. Not sure if I trust the local shop with the complex airbag electronic components. Anyhow, how much they charge you to reset those lights? Just the diagnostic fee I presume?
04-03-2023, 12:58 PM | #5 | |
04-08-2023, 07:20 AM | #6 |
So I haven’t had a chance to go to the dealer yet as all the ones around me are backed up and I don’t want to leave my car there for days.
I plugged an OBD2 reader with airbag read capability and it gave me code B0014-0D Driver seat side air bag deployment loop - high resistance What should I be troubleshooting from here? |
04-08-2023, 08:27 AM | #7 |
Drives: 2013 ZL1 Join Date: Sep 2021
loose connection-broken wire.
04-08-2023, 09:46 AM | #8 |
^^^^ Yep, this. Check your connections and wires. Unplug it, then plug it back in, clear the code and see what it does.
04-08-2023, 03:36 PM | #9 |
I checked all under the seat, they look snug. Should I be disconnecting and reconnecting? Should I be taking the seat cover off via back zipper and looking? Are there connections in the driver seat airbag area? Where on the driver seat should I be looking?
04-11-2023, 12:08 PM | #10 |
I'm not sure, I didn't see him do the install. I'm assuming that there is a wire coming down out of the seat back for the AB and connects to a harness under the seat. That is where you might want to look at the connectors and make sure they are all good and that no pins got bent on the re install.
04-12-2023, 09:18 PM | #11 |
Drives: 2010 2LT/RS Join Date: Mar 2015
What are these katzkin covers I am now hearing about? Can you post pics of what they look like in your Camaro?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
04-14-2023, 09:23 AM | #12 |
Solved!!! The driver side airbag plug was disconnected. Had to remove the seat and unzip the back to get to it. Light never came back on. As always thanks to the wonderful folks in this forum. Couldn’t have done it without y’all.
04-17-2023, 09:39 AM | #13 |
AWESOME sir!! Yea my next thing I should have let you know about and forgot, was the connector INSIDE the seatback, that one has to be disconnected with the swap too. Glad you found it.
04-17-2023, 09:46 AM | #14 | |
