09-13-2015, 04:34 PM | #1 |
Drives: 2011 Camaro 2SS RS L99 Vert Join Date: Aug 2015
Programming the Manual Mode to be TRULY aggressive.
According to the 2011 SS owners manual the shifts in Manual Mode (without using Tap Shift controls) are supposed to be more aggressive than when in Drive. I personally can't feel the difference. But anyway, doesn't that mean that it should be possible to reprogram the Manual Mode to truly be more aggressive? This way when the car is in Drive it will operate as stock for economy, wife driving it, etc. Then Manual Mode it could be programmed to shift hard, stay in low gear, and have AFM disabled.
This is what the manual says: "While driving in M(Manual Mode), if Tap Shift has not been activated, the transmission determines when the vehicle is being driven in a competitive manner. It selects and holds the transmission in lower gears and has more noticeable upshifts for sportier vehicle performance. See Manual Mode on page 9‑32 for more information." |
09-13-2015, 05:24 PM | #2 |
War Horse Pilot
I believe good tuners are able to tune D, M and Tap Shift settings differently. I think the AFM would just be off completely though. Not sure if the can enable it for D, but off in M and Ztap Shift. Might be able to...
09-13-2015, 05:35 PM | #3 |
Drives: 2006 F150 Lariat Join Date: May 2010
This. Sport mode slams gears in my car. I don't use TapShift unless I'm downshifting to hear my exhaust lol...
09-13-2015, 07:34 PM | #4 | |
I guess a Diablo tuner for example wouldn't be able to do that. It would take something more sophisticated. |
09-13-2015, 07:39 PM | #5 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
I had my l99 tuned and Sport Mode is very stout. I had to have Dynosteve soften my 1-2 as it was neck snapping and locked my seatbelt a couple of times lol. Chirped first 3 gears shifting too....Its nicer now in D but S is still aggressive but good so far. I'm still testing it out to see if I'm done with adjustments. AFM is either on or off not gear mode specific. Just turn it off...
I know the OP asked about tuning before in another thread. Now that I've done mine I can say holy $hit is this car impressive and is otherwise stock.... I agree D and S were virtually the same but not anymore. Do yourself a favour PM Dynosteve and let the L99 loose once and for all! |
09-13-2015, 07:44 PM | #6 |
I'm sure the Diablo can turn it off but forget the canned tune. Most Tuners will give you a free custom tune with the purchase of the handheld device. I'm using the SCt X4 with a custom tune by Dynosteve. This man is an absolute gent and pro. He doesn't care how many adjustments you ask for to have the car the way you like it and never charges for tweaks! just do it!
09-13-2015, 07:45 PM | #7 | |
09-13-2015, 07:46 PM | #8 |
09-13-2015, 07:50 PM | #9 |
Drives: 2013 Dusk 2ss/RS conv. Join Date: Jul 2015
How do you set the sports mode? May be a dumb question. It has the L99 6 Auto.
2013 Dusk Camaro/Convertible/2SS RS/6 Speed Auto/One of Sixty Nine
09-13-2015, 07:52 PM | #10 |
09-13-2015, 08:00 PM | #11 | |
Read 9-28. You can download the 2013 manual at https://www.chevrolet.com/content/da...k13camaro1.pdf Last edited by yescats; 09-13-2015 at 08:56 PM. |
09-13-2015, 08:20 PM | #12 | |
Dynosteve said this to me about mine "will have a different feel in d to m sir, just let me know if you want me to adjust that for you" So I take that to mean you can have that... |
09-13-2015, 08:40 PM | #13 | |
My S-Type Jag only has 238HP but it's amazing how peppy it is because it downshifts and upshifts right at the perfect times. But when I first got it the programming sucked. It was a dog. When they updated it the change was miraculous. The program seems to keep the RPM's closer to where the power is. My Camaro seems to be programmed to get into 6th gear as soon as possible and stay in the tall gears as long as possible. |
09-13-2015, 09:59 PM | #14 |
No that hasn't changed much really. I would prefer that to be the case too. I might look into having that tweaked by my tuner but I'm still getting used to the car. It could the tranny itself making it do that I'm not sure.
