04-28-2016, 02:16 PM | #1 |
Drives: 2012 (ZL-1) #468 Join Date: Apr 2012
Summer Start-Up
My Car Goes Into The Garage 1st Week In October For The Winter - I'll Be Bringing Her Out For The Summer Next Week - How Can I Turn Her Over Without Starting Her To Get The Oil Thru The Engine First - Then Fire Her Up Without Should A Harsh Dry Start?
04-28-2016, 03:10 PM | #2 |
Let's go fishing!
Drives: a car with 8 cylinders Join Date: Apr 2016
I'm not sure how the ZL1 is engineered, but you could unplug the coils and pull the fuel pump fuse to turn the motor over a few times. Either way you do it, the motor will turn over dry until oil pressure can build and squirt oil where it's needed. There could be a way to turn on the oil pump, but I don't know how to do that.
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
04-28-2016, 03:14 PM | #3 |
Let's go fishing!
Some people may say to turn the crank with an impact, or breaking bar... you don't wan to do that either. You could put more pressure than needed on that bolt and snap/strip/grind the head smooth. Additionally, you will still be turning it over dry until pressure builds up enough for oil to get to where it needs to be.
04-28-2016, 06:13 PM | #4 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
With the roller valve train you don't have to worry about the cam, lifters and the valve train, they are fine. The only issue is the piston rings and cylinder walls drying out. Remove all the spark plugs, squirt some engine oil in each spark plug hole. Let it sit over night. In the morning squirt some more engine oil in each spark plug hole. Then bar over the engine by hand about 5 complete revolutions. After you have bared it by hand, spin the engine using the starter until all of the oil vapor blowing out of the spark plug holes is gone. Screw in the spark plugs and start it up.
Good luck Last edited by Dimitrim; 04-28-2016 at 06:32 PM. |
04-28-2016, 10:44 PM | #5 | |
Drives: 2015 Camaro ZL1 (red hot) Join Date: Dec 2014
It will be fine!! Been starting my boat, motorcycle, tractor, Camaro after sitting through the winters all my life, no problems. |
04-29-2016, 08:41 AM | #6 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
You normally just turn the key. LS motors notoriously have some valve noise (except lsa...strange), and what I found to be effective is to turn the key on the "on" position for about 5 seconds, and then start (for cold starts and for cars that have sat for a few months). In the past, I used to get the clankety clank valve noise from my ls2 truck after it sat awhile or during a cold winter start; After using the 5 second delay technique I described I haven't had the loud valve noise from a cold start, so it seems to work for me.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
