JUICEDMOTORSPORTS
Old 06-15-2014, 06:16 PM   #1
Emvici
Drives: 2014 ZL1 White Convertible
Question Boost Gauge
Ok, I am sure I am not the only one who feels this way, and knowing this, I wonder if there is already a solution out there?. The boost gauge imo is one of the more important gauges to watch, especially during the times you need your eyes looking through the windshield. Why Gm felt putting it under the dash was a good idea?. Anyone know of a way to program it into the Hud, or move it somewhere better suited for competitive driving?.
Emvici is offline   Reply With Quote
Old 06-15-2014, 06:37 PM   #2
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
So why is a boost gage needed in line of sight? There is nothing to change or watch out for?
Can not change anything while driving. If the boost was to go too high or quit, the CEL will come on.
That's why it's not in the HUD. Temp gauges are important.
Skylane765 is offline   Reply With Quote
Old 06-15-2014, 06:52 PM   #3
Emvici
I like to know how much boost is charged in the system before I consider getting on the gas or before considering a gear shift.
Old 06-15-2014, 07:15 PM   #4
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
WHAT?
I have a Dashlogic by Palmer Performance Engineering.
It plugs into the OBD port under the steering column and can display the boost or any other diagnostic read-out available to the ECM on either the DIC, HUD or the Radio Display. (or all 3 displays)
No extra wires are required and no mods to the car.
I did this so I didn't have to install a gauge pod or other wiring to monitor certain things from the ECM.
I have my boost display in the HUD and it works great.
Also controls the Exhaust via the Cruise Control switch.
Not sure what you think is happening or not happening by your post above in reference to "charged boost in the system"???
2013 ZL1 #7860 is offline   Reply With Quote
Old 06-15-2014, 11:17 PM   #5
Emvici
what I mean by "charged boost in the system" is, I noticed I can be in any gear, 1,2 3,4 ect and depending on how quickly I build up the rpms the boost will build up less or more and faster. So I can be in 3rd gear at 3000 rpms and have 7 psi of boost or I can be in 3rd gear at 3000 rpms and have 11 psi of boost, depending on how quickly I built up the rpms. Thank you for the referral to dashlogic, I will check them out. It sounds like a nice product.
Old 06-15-2014, 11:25 PM   #6
blake2010ss
blake2010ss's Avatar
Drives: 2010 Camaro 2ss/rs
Send a message via AIM to blake2010ss Send a message via MSN to blake2010ss
i was told about the dashlogic (dont have one) and was said that it is a great product as well.
i am still confused a bit by your post above post though.
2010 Camaro 2SS/RS LS3
1093/1066
416, AGP 6262, E85, Cam
blake2010ss is offline   Reply With Quote
Old 06-15-2014, 11:32 PM   #7
Emvici
Well just purchased the dashlogic device. It looked really good, seems to be able to do everything I would like, so I jumped on it. I hope I am happy with it. thanks again for the referral for the product.
Old 06-15-2014, 11:33 PM   #8
Emvici
well I am new to superchargers ect.. what part am I not communicating clearly to you?.
Old 06-15-2014, 11:34 PM   #9
PalmerPerformance
PalmerPerformance's Avatar
Drives: 2013 RS/SS M6
As others have mentioned, DashLogic can put boost where you want it. AND you can watch intake temps as well right next to it if you want to see what effect boost air temps have on your boost readings? Really you can put what you want on the HUD as long as space permits. 16 characters per line with 2 lines available on the HUD.
http://www.camaro5.com/forums/showthread.php?t=348508
PalmerPerformance is offline   Reply With Quote
Old 06-15-2014, 11:51 PM   #10
2013 ZL1 #7860
Awesome! You won't be disappointed. The customizable ability is amazing! Huge bang for buck mod.
Superchargers are belt driven so the supercharger is spinning at the same speed per engine rpm regardless of the gear the car is in. Thus at 3,000 rpm in 1st or 3rd gear the same boost is being made.
The car however has a bypass valve which bypasses this boost back in front of the supercharger if it is not needed based on throttle position and engine load.
Boost does not build into something that is being stored or has to be "made" like a turbo. When the bypass valve closes based on throttle position then ALL available boost is instantly directed into the motor. (think on/off switch)
Boost does gradually rise as rpm rises at wot due to restriction in engine cfm flow at higher rpms. The faster the air has to move in the engine the "thicker and stickier" it becomes and harder to flow as the result.
Boost is somewhat of a useless thing to monitor as an engine that can move more cfm will build LESS boost (restriction) but make more power. Boost can be thought of as restriction in the system and less is not necessarily a bad thing.
I once had a Supercharged car that had a blocked cat and before I realized it, I went WOT and it made 3 times the boost of normal and then fell on it's face and was dog slow the whole time. (according to a "ricer" how much boost? mindset it was the fastest thing on the street)...
The term "how much boost" a car is "on" or "making" is a quick and simple way to quantify to others how hard the forced induction is working. But it does not account for the cfm or flow of air at all, just the pressure the intake air is under. Cfm makes power, boost gives ricers something to talk about.
Old 06-16-2014, 12:32 AM   #11
Skylane765
Skylane765's Avatar
What? It makes no sense. You shift by RPM not boost! There is no use to know the boost while driving, there is nothing it can tell you what to change. It's like fuel pressure or oil pressure, works or it does not work.
Old 06-16-2014, 08:48 AM   #12
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
I hear a lot of people complain about the guage placement, but personally I like them a lot. It will be missed if chevy cuts them out on the next generation.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
lbls1 is offline   Reply With Quote
Old 06-16-2014, 09:01 AM   #13
Emvici
well, I learnt a lot reading the posts replies here. I could see that the boost was climbing as the rpms where picking up, but I didn't realize is was because of throttle position, and not because of how fast I was build rpm's.
However, I would still like to be able to see when I am in the boost.
Old 06-16-2014, 09:10 AM   #14
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
the more important thing to look at is fuel pressure. but if you are stock you dont have to worry about it. the computer will take care of everything. but for me it is important because i am running a BAP with a stock non ZL1 pump. running out of fuel on a boosted car is a bad thing. the boost gauge is more of a cool thing to look at unless you are trying to figure out a problem.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
