#Camaro6
Old 04-08-2019, 10:03 AM   #1
Jaysatthelake
Drives: 2019 2SS 6 speed convertible
Factory CAI performance numbers
Has anyone figured out what the HP is when you get the factory CAI ? Aftermarket vendors claim up to 15 HP gains and it sure appears the GM version is pretty much the same.
Jaysatthelake is offline   Reply With Quote
Old 04-08-2019, 10:16 AM   #2
RyanR623
Drives: SS A8, NPP, Red Hot
Little to none. It's more of a sound mod on a stock car. I did it on my 6.2 F250 super duty just for the sound, and it sounded great. Not $400 great, but good.
RyanR623 is offline   Reply With Quote
Old 04-08-2019, 10:19 AM   #3
CRF8
Scenic City Camaro
CRF8's Avatar
Drives: 2022 Camaro ZL-1 /1974 Firebird 400
I agree with Ryan , don’t expect much. On my 2014 I got throttle body, CAI and a tune, just barely saw a difference.
CRF8 is offline   Reply With Quote
Old 04-08-2019, 11:35 AM   #4
Jaysatthelake
When you say "sound" what do you mean ?
Old 04-08-2019, 12:00 PM   #5
yankee
yankee's Avatar
Drives: 2018 Camaro LT RS, 2015 Mazda 3
Turbo sound is enhanced. I don’t know how it works for non-turbo models
yankee is offline   Reply With Quote
Old 04-08-2019, 12:01 PM   #6
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
No gain, sorry with the CAI intake from GM. More noise and very cool looking, yes. So I think it is a great mod with no lost sleep over warranty issues. And the tune, while no gain there either smooths out the airflow and avoids erroneous throttle closures that happen with some CAIs on a stock tune. (as has been explained to me.)
The stock LT1-DI intake flows pretty well apparently. Even the best aftermarket tuneless CA6 LT1 CAI only gives +3-5 RWHP as proven on my 2016 M6 SS.
Old 04-08-2019, 12:07 PM   #7
RyanR623
Yeah hear the growl of the engine more. Kinda hard to explain. Also if you step on the gas quick, you can hear a suction noise. Engineers dedicate a lot of time to getting rid of both those sounds.
Old 04-08-2019, 12:13 PM   #8
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Most intake systems incorporate silencers and/or significantly cut down on engine noise. Going to a short-ram on my WRX, which bypassed the stock silencer, I got the "pssshhht" turbo BOV noises all over. Lots of people thought you needed to "upgrade" the BOV to do this, but the only reason for that is to hold more pressure from a much larger turbo. The intake is what made the noise happen. On the NA engines, it's similar, you get more NA engine noise coming out the intake, just like how the stock sound-tube on the V8s pipes intake-engine noise into the cabin. Kind of lame, but at least it's not fake noise. Aftermarket intakes generally make more noise, so you think you are going faster/making more power.
As far as actual gains, in most cases they do not, in most of the remaining cases, they simply change the power/torque curves a bit, not changing the total, but giving a little here and taking away over there. The air going into the cylinders is dictated by the pressure and sensors and there's a fixed amount of air and fuel that can be crammed in there. If you want to cram in more than ambient pressure, you need forced induction.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 04-08-2019, 12:26 PM   #9
Jaysatthelake
That really answers my question and then some, thanks a ton !!!
Old 04-09-2019, 04:03 PM   #10
Fraxum
Fraxum's Avatar
Although a CAI can make your car faster. On the 5th gen LS3 you could pick up 15-18 HP proven on a number of dynos. In my '11 SS I added a CAI CAI (Cold Air Inductions) Like the current factory CAI. Now dynos are one thing, but by adding the CAI, the under-scoop, and and a set of Nitto NT555Rs (a not well regarded DR) I went from running 13.2s to 12.7s with just those two mods and my 60's only decreased by about 1/10. That mod set was my most cost effective bang for the buck ever.
It all depends on what you start with. on the CA6 SS you have a good intake and exhaust shorties. This is also why long tubes also don't do much by themselves even with a tune. But both are integral parts for a full bolton car.
Old 04-09-2019, 05:16 PM   #11
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Any opinions on the momentum GT? Seems to have a fairly significant increase in airflow. I'm planning on pairing that with American Thunder exhaust. I don't expect performance increase per say, but at least better sound.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
Black on black 2019 3LT RS Camaro.
1100: 3/7/19 | 4200: 4/15/19
3100: 3/15/19 | 4800: 4/23/19
3400: 3/22/19 | 5000: 4/25/19
Built: 4/8/19 | Home: 4/26/19
RideWithDanger is offline   Reply With Quote
Old 04-09-2019, 05:30 PM   #12
enzia35
Drives: '16 Garnet Red 1SS
Considering it's pretty much a rebadged CAI brand intake, you'll be losing power.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 04-09-2019, 07:08 PM   #13
Jbanta1983
Drives: 2019 2ss 1LE
I don't carewhat anyone says I just installed the cai intake onmy 19 SS 1le and i absolutely feel a difference from mid to
To top end. Get the cai intake
Jbanta1983 is offline   Reply With Quote
Old 04-09-2019, 08:29 PM   #14
RideWithDanger
Drives: 23 2SS 1LE
what is? And how is CAI brand bad? They are making a new intake for the V6 soon as was considering it. looking into AFE for the momentum GT and I don't expect to really gain anything other than sound, but I doubt id lose power. What do you suggest?
