Old 08-06-2019, 11:46 PM   #1
prd72
prd72's Avatar
Drives: 14 Z/28 #180
Track Day Maintenance
I'm doing a track day at the end of the month and I need to do the following:
Change engine oil/filter
Transmission fluid
Rear diff fluid
Brake fluid DOT 4
Any recommendations on brands would be appreciated and good places online to buy.
Anyone know the min thickness of pads and rotors. The link from another thread was dead.
Thanks
prd72 is offline   Reply With Quote
Old 08-07-2019, 08:13 AM   #2
1970judge
Drives: 2015 Z/28, 2007 HHR
I use:
1) Mobil 1 15w-50 and PF64 (track prep guide)
2) GM OE trans fluid
3) GM OE diff fluid
4) been running AP racing radical R2, but switching to Castrol SRF.
Its not the rotor thickness, its the weight. They have a min weight.
TRACK PREP GUIDE HERE: https://www.camaro5.com/forums/showthread.php?t=493755
My auto related blog:www.camarohistorian.com
1970judge is offline   Reply With Quote
Old 08-07-2019, 08:27 AM   #3
Biergut
Biergut's Avatar
Drives: '15 Z/28
I stick to Mobil 1 for oil (weight is your call -- I use 50 for track)
I follow the Chevrolet recommendations for fluid as they have not steered me wrong. Have had issues with high end/priced diff and tran fluids in the past in a Corvette.
My brake fluid choice is Castrol SRF. Flush once a year and never need to bleed during the season of about 12-15 days.
Pads: You are for the most part done at 4mm. Reminder the thinner they get the faster they use material (heat). If your car has low miles you'll not have to concern yourself with rotor weight. Plenty of threads on here about the CC rotors and when and how to determine whether they are used up.
Correct me if I am wrong, but it sounds like your first track day... if so, I wouldn't be to concerned with all the fluids, pads, etc. if your car has been maintained per factory recommendations. Go, have fun, change fluids afterward. The factory pads are of high quality.
BG
Transmission fluid
Rear diff fluid
Brake fluid DOT 4
Thanks
Biergut is offline   Reply With Quote
Old 08-07-2019, 08:44 AM   #4
j o n
j o n's Avatar
Drives: 2015 Z/28 #00048
Follow the PDF in thread
https://www.camaro5.com/forums/showt...ht=track+sheet
Current:
'15 Z/28 #00048 | White | A/C | Speakers | Michelin PS4S 305/30/19's
'19 Civic Type R | White | Wing delete
'16 CR-V EX-L Navi | AWD | White | Ebony
https://www.instagram.com/__jon__athan__/
j o n is offline   Reply With Quote
Old 08-07-2019, 09:18 AM   #5
MrRaZ28
@MrRaZ28
MrRaZ28's Avatar
Drives: 2014 Z28 #80
I will be the one nay-sayer in here and tell you to stay away from Mobil 1. Joe Gibbs, Valvoline, or Redline 15W-50 for the track. DO NOT USE 5W-30. I learned this the hard way, with 12 out of my 16 rockers to being damaged. Not worth the chance of valve train failure.
As for the rest, everybody is spot on. I've been using Motul 660 for my brakes and I haven't had any fade yet, but I'm thinking of giving SRF a shot next go around just to compare feel.
Formerly Chevy2tehB0ne
IG: @razinha_motorsports
MrRaZ28 is offline   Reply With Quote
Old 08-07-2019, 10:06 AM   #6
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE & 2014 Z/28
My 2 cents: I've been using Castrol SRF for several years and have been pleased overall but started noticing the brake pedal travel was long. I did some research and found that the SRF fluid compression is one of the worse among high dollar brake fluids.
I have recently switched to the Brembo HTC fluid and have noticed a significantly more responsive pedal that stays very consistent through long runs.
As others have stated, I use the recommended Mobil oil, 15w-50 and the AC-Delco diff fluid and change both every two track days.
GMteSSted is offline   Reply With Quote
Old 08-07-2019, 10:20 AM   #7
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
Same here for items 1-3, except I am using Motul 660 for brake fluid. I would not hesitate to use Castrol SRF either.
Originally Posted by 1970judge View Post
I use:
3) GM OE diff fluid
AustexaSS is online now   Reply With Quote
Old 08-07-2019, 11:24 AM   #8
SCZ
Drives: 2015 Z/28
shoulda woulda coulda... took my recently purchased 10k mi Z/28 for the second track day yesterday and boiled the brake fluid during the third session. Guess I'll be more mindful of fluid changes from here on.
SCZ is offline   Reply With Quote
Old 08-07-2019, 12:20 PM   #9
MrcamaroZ28
MrcamaroZ28's Avatar
Drives: 2015 Black Z28
how did you know you boiled the brake fluid???
MrcamaroZ28 is offline   Reply With Quote
Old 08-07-2019, 12:44 PM   #10
SCZ
Drives: 2015 Z/28
started to lose the pedal. came off the track and the pedal went to the floor. no brakes at all. let it cool down and had brakes. changing all fluids before we drive it again. glad to see the track prep pdf on here today! couldn't have been posted at a better time for me. live and learn.
Old 08-07-2019, 01:04 PM   #11
prd72
prd72's Avatar
Thanks for the info guys
Not my first time to the track but only get 1 or 2 events a year. Only one this year.
Old 08-07-2019, 07:20 PM   #12
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
I'm a huge fan of Amsoil lubricants (I run it in everything) and Castrol SRF (it has the highest wet boiling temperature, once a can of brake fluid is opened I consider it wet)
Good luck
Craig
A man's garage is his castle
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
SS Performance is offline   Reply With Quote
Old 08-08-2019, 01:03 PM   #13
Biergut
Biergut's Avatar
Drives: '15 Z/28
Good luck
Craig
My Corvettes never liked Amsoil in the differential... noise, clunks... all solved by going back to the factory LS diff fluid with their additive.
I'd run nothing else.
Old 08-08-2019, 01:27 PM   #14
j o n
j o n's Avatar
GM's trans fluid offers similar results
Current:
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
