05-31-2014, 08:47 PM | #1 |
Drives: 2013 Camero RS 1LT Join Date: Apr 2014
Low LOC RCA Voltage
Hey Guys,
Long time lurker, first time poster. Here's my setup: 2013 Camaro 1LT RS
Here's my problem: I'm having a weird issue with my audio setup. I assume it's due to a bad LOC but before I purchase a new one/return the old one, I wanted to see what you guys thought and rule out a n00b setup issue on my part. I'm seeing really low voltage out of the LOC's RCAs. When setting the radio's front to rear balance to two ticks from all the way in the rear, and the volume set to 45, and the LOC's gain set to max, I measure no more than 0.65VAC and nominally 0.3-0.4v coming from the LOC's RCAs. Voltage measured on the loc's input side from the rear speaker lines is 3.6v. The LOC's manual implies that up to 8v should be achievable and demonstrates a 4v RCA line level output. I've had to max out the gain on the amp and the fronts still drown out the rears without the extreme speaker balance setting. Thoughts? |
06-01-2014, 12:42 AM | #2 |
Drives: 2018 1LE Join Date: Feb 2013
Most amp only take a 4 v input. Also gains are not volume controls the are use to match the output leave of the radio to the input leave of the radio. What type of multimedia are you using and where is it set when metering. If you won't to boost the out put of the radio audio control has a few new pieces out.
06-04-2014, 06:38 PM | #3 | |
Anyways, I wired up the Amp's high input wiring harness to my rear speakers and that solved the problem. I'm now only using the LOC for the AMP turn on signal. The LOC's high to low circuitry was DOA apparently. |
