07-05-2020, 12:59 AM | #1 |
Drives: 2010 2SS/RS Join Date: Dec 2009
Radiator Choice
Looking at the Champion or the Mishimoto both are under 400 and don’t see the Ron Davis or Dewitts at over 600 bucks, I don’t wanna a radiator is a radiator but dam the difference in cost is kinda ridiculous.
So if you had a choice which would you go with or know of another alternative for a all aluminum radiator.
Orange Krush II
07-05-2020, 02:35 AM | #2 |
There is no sense in changing rads unless you are going with additional cores.
You can change the rad all you want, the T-stat will still be your baseline. |
07-05-2020, 07:18 AM | #3 |
8.60 @ 157 @ 4200lbs
Radiator
Im running mishimoto. Over 5 years 1000 hp + no issues
2010 camaro twin turbo 8.60 @ 157 full weight 4200
07-05-2020, 08:45 AM | #4 |
Stock does fine until 550hp NA or 850hp boosted and that's only in the hot regions of the US.
07-05-2020, 01:01 PM | #5 |
True But
The Mishimoto and the Champion have more cores I believe and if not are they are bigger cores and I’m running a 168 t-stat an yes while what you said is true it will take longer to get hot with added capacity.
Orange Krush II
07-05-2020, 01:03 PM | #6 |
Road Course
Bo going to be road racing the car and approximately 500 hp to the tires so a lot of additional stress if just a daily driver completely agree.
Orange Krush II
07-05-2020, 01:05 PM | #7 |
Did You Notice
Did you notice a difference??
Orange Krush II
07-05-2020, 01:20 PM | #8 |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i got this as far as i can tell it's the same as the champion.i kinda showed what i did.it fit the fans perfect and the condenser.the only snag was the trans lines if i did it again i would stick with the stock but this was cheaper decent quality and has more cores.
the listing has a make a offer i offered 170 they accepted and i ended up at 181.48 because of tax.to use it i needed check it out https://www.camaro5.com/forums/showt...=576270&page=2 https://www.ebay.com/itm/3-Rows-Alum...72.m2749.l2649 |
07-31-2020, 11:42 AM | #9 |
Drives: '23 LT1 A10 Join Date: Oct 2015
in for later
07-31-2020, 12:04 PM | #10 |
Drives: 5th Gen L99 Join Date: Nov 2017
I live in az in 115+ weather my car runs just like stock. Coolant is about 199 moving and up to 225 in stop and go or idling. Oil temps about 226 usually, and trans temps 185-190. Are you having cooling issues?
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
07-31-2020, 12:50 PM | #11 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think just about everyone that road courses at least has the potential to have overheating problems.
07-31-2020, 01:00 PM | #12 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
I just bought a mishimoto radiator. haven't installed it yet as I am still waiting on my oil cooler to come in the mail so I can get that in first. the thing looks great (outside of the car) and well made. the only issue I am seeing right now is it looks like they got some spots from welding inside the holes at the bottom your plastic fan shroud goes into. so it doesn't really fit in there without doing some minor trimming on the fan shroud. I don't know if this is an issue with all of their camaro rads or I just got the lucky bad draw lol
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
07-31-2020, 11:07 PM | #13 |
Good info on both Champion and Mishimoto an I plan on running a external cooler for the trans as well.
Orange Krush II
08-01-2020, 06:02 PM | #14 |
Drives: 15 Camaro SS Join Date: Oct 2018
running a mishimoto here. Nice rad. Fit great and seems to be top quality. Car runs cool, no issues
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
