08-07-2020, 07:35 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jul 2020
What spoiler is this?
Hello - looking to see which spoiler is on this car. I like the look of it but can’t seem to find the name of it. Thanks!
08-07-2020, 08:14 AM | #2 |
Tri-County Camaro SWFL
Looks like the Anvil spoiler. Got one on my car.
08-07-2020, 08:24 AM | #3 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Yes, that’s the Anvil Spoiler. I think they are hard to find now. Not sure if they are still being produced.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
08-07-2020, 12:22 PM | #4 |
Drives: 5th Gen L99 Join Date: Nov 2017
Correct me if I’m wrong, but I though Anderson’s composites had something similar to that.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
08-07-2020, 02:24 PM | #5 | |
https://anvilauto.com/products/camar...-spoilers.html
08-07-2020, 02:54 PM | #6 |
I'm emailing Matt Lazich at Anvil and they can't tell me if their notched spoiler (010526) will fit my 2014 ZL1. He said it fits the SS and told me to ask the dealer.
Are there any ZL1 owners that used this spoiler and can tell me if it fits?
08-07-2020, 03:26 PM | #7 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2016
Been awhile since I've really looked into spoilers but I believe the only difference between the ZL1 and SS is that the ZL1 has a hole for the wiring to run into the interior for the 3rd brake light(SS has it inside the back window). Anvil spoilers are direct bolt on for the SS so you would just want to plug that extra hole so no water can get into your trunk. Maybe someone that has gone from ZL1 to Anvil will chime in.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit |
08-07-2020, 03:31 PM | #8 |
Good point on the 3rd brake light. I'm OK with sealing the hole. I've read the ZL1 and Z/28 are the same, but dang this is confusing. I just want a high spoiler thats a true carbon fiber look to match my factory hood.
08-07-2020, 03:44 PM | #9 |
I remember people using some sort of rubber grommet to fill in the hole, you might be able to find it if you search around on the forums. Whatever it was it laid flat enough on top of the decklid that it doesn't interfere with how the spoiler sits and it isn't visible. I vaguely remember people also using some sort of color matched sticker thing or vinyl as well to cover it up, hard to remember exactly that far back
491 hp/438 tq
08-07-2020, 05:42 PM | #10 |
Flex Tape! LOL
I'm more concerned that it will line up with the mounting holes. I can manage the hole that the wiring was feeding through. Matt best solution so far was to have me remove my spoiler and send him my dimensions and he said he'll see if he can match it up. A lot of work to find out it wont fit, but I might have to do it. I think I would probably like a carbon fiber Z/28 spoiler just as well. I read they are the same mounting. Looking at ACS now. Thank for the help!
08-07-2020, 05:52 PM | #11 |
Actually after taking another look at my car, the 3rd brake light is in the trunk lid, not the spoiler so thats good.
Looks like I might have found one. but a bit pricey. https://www.phastekperformance.com/1...4chcam-z28.htm
08-07-2020, 07:19 PM | #12 | |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
08-07-2020, 08:36 PM | #13 |
RIP Betsy ( Vitara )
omg this actually might be avail again???
I want it.
First retrofitted 2014 mylink. |
08-08-2020, 03:24 PM | #14 |
Mauimax3
Just got mine a couple weeks ago. It mounted perfectly, lined up with all the existing stock spoiler holes. Added ZL1 addon wickerbill since.
Magnuson Supercharger, ZL-1 Fuel Pump, Kenny Belle Boost-a-Pump, Kook's LongTube, BTR Stage II, Trunion upgrade, ATI Superdampner, Nick Williams 102mm, Elite Eng. Can, Borla ATAK exhaust w/flow thru cats, CAI box. BMR Suspension upgrades. Dr Phil tuned.
