10-28-2010, 04:22 PM | #1 |
Drives: 2011 Camaro LT Silver Ice Join Date: Jul 2010
Nitrous filled tires?
Hi All, I went to put some air in my tires this morning and I wento to the garage bay and asked the guy on duty if he could fill my tires. Before I could get out of the car he tells me he cannot do it. I said "why?" He said you have nitrous filled tires. I have the 19in tire upgrade on my camaro.
The big question is how do I get it filled? Is there a portable version of nitrous gas that I can keep in the garage?? How does anyone else handle this? Thanks |
10-28-2010, 04:24 PM | #2 |
Drives: 2010 Camaro 1LT RJT Join Date: Feb 2010
Its nitrogen.. your dealership shouold have it. Most tire places do. Not sure if you can have it in your garage..
10-28-2010, 04:24 PM | #3 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Nitrogen. It does not expand & contract like plain air and is denser so leaks less. Nitrous is an entirely different compound. You can add reg air any time if needed.
10-28-2010, 04:26 PM | #4 |
Drives: 2010 ABM 1LT/RS Camaro "Blu Bruzr" Join Date: Oct 2009
hmmm.. i can get mine filled anytime from work, but i guess you would need a tire shop, or a wal-mart, costco (where i get mine) or any other places that have tire shops
VIN: 2G1FB1EV6A9178865 |
10-28-2010, 04:27 PM | #5 |
Drives: 2011 GT500 Join Date: Jun 2008
10-28-2010, 04:27 PM | #6 |
Drives: Fifty 2SS Vert Join Date: Dec 2009
Not nitrous, by the way, that's highly combustible.
I think he meant nitrogen. IMO, nitrogen filled tires is a waste of time and money. Considering regular air is about 2/3 nitrogen anyway, what's the point? Gimmick to make cash, that's what it is........ |
10-28-2010, 04:28 PM | #7 |
sorry about that
Sorry about using the wrong name of the gas in the tire. The guy at the station said he didn't want to add air because he said it contains water and it would knock the tire balance off.
10-28-2010, 04:30 PM | #8 |
10-28-2010, 04:44 PM | #9 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Nitrogen molecules are larger than other molecules and therefor won't leak out as fast as other gasses, pure nitrogen will also not contain any moisture which will expand and contract causing large fluctuations in hot versus cold tire pressure. Nitrogen is also a noble or inert gas which will not support combustion or life. (don't try breathing it, you will die)
Liquid nitrogen is also extremely cold (-320F) and makes ice cream freeze faster and smoother. |
10-28-2010, 04:46 PM | #10 |
And you can freeze stuff with it and it will shatter
10-28-2010, 04:50 PM | #11 |
Nitrogen molecules are larger than other molecules and therefor won't leak out as fast as other gasses, pure nitrogen will also not contain any moisture which will expand and contract causing large fluctuations in hot versus cold tire pressure. Nitrogen is also an inert gas which will not support combustion or life. (don't try breathing it, you will die)
10-28-2010, 04:50 PM | #12 |
Drives: 2011 SS Join Date: Oct 2010
You should see if you can get them filled with helium.. It improves your quarter mile time considerably from what I hear
10-28-2010, 04:53 PM | #13 | |
Drives: 2011 2LT - 73 Corvette 454 Join Date: Sep 2010
I had a set of tires from Costco on my pickup that were filled with nitrogen. When I needed a little air, that's exactly what went in there! A little air from the compressor in my garage. Works fine. |
10-28-2010, 04:54 PM | #14 |
air is primarily made up of nitrogen (78.09%) and oxygen (20.95%). The remaining 1% is made up of argon (0.93%), carbon dioxide (0.03%) and other trace gases (0.003%).
Ok I was wrong, there's actually MORE nitrogen in plain old air than 2/3 so I guess the big molecules will plug the hole |
Similar Threads | ||||
Nitrous System ?????s | PoleCat2SSRS2010 | Forced Induction - V8 | 29 | 12-08-2010 05:55 PM |
All season tires on RS??? | iyam_lorne | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 10-07-2010 09:25 AM |
Tires... flat spots | jrcase | 5th Gen Camaro SS LS LT General Discussions | 27 | 03-02-2010 09:03 PM |
Winter Tires - Reminder about TPMS | KJS | Wheels and Tires Talk Sponsored by The Tire Rack | 3 | 11-22-2009 07:39 PM |
Help with selling a car: tires | Teddydog | General Automotive + Other Cars Discussion | 2 | 08-03-2009 01:28 AM |
