07-20-2011, 03:31 PM | #1 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
Quick question about Jba mid pipes
Will the factory hardware work with the Jba High flow catted mid pipes? Like the gaskets and bolts/nuts at the manifold? Thx
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
07-20-2011, 04:33 PM | #2 |
Drives: White 2010 RS/SS Join Date: Dec 2009
07-20-2011, 05:15 PM | #3 |
knows 2 facts about ducks
yes they do.
07-20-2011, 06:51 PM | #4 |
Thanks for the post, but I found out first hand they won't.
07-20-2011, 07:47 PM | #5 |
I installed mine and reused the OEM gaskets and the OEM bolts. Didn't strip the O2 sensors either. It was a piece of cake install really, though the top O2 sensor on the driver side is a PITA to get back in.
07-20-2011, 07:54 PM | #6 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
Yup
07-20-2011, 08:05 PM | #7 |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
Why not just use the hardware they ship with the Cats?? I just received mine and they come with new hardware.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
07-20-2011, 08:07 PM | #8 |
Drives: 2011 Camaro SS Join Date: Nov 2010
+2 All the hardware is with the cats.
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery |
07-20-2011, 09:04 PM | #9 |
07-20-2011, 09:13 PM | #10 |
No the factory hardware will not work. The factory mid pipe is threaded with studs that go in it. In the Jba pipe it's slotted. No go there. The factory gasket did not look like it was going to be a good fit and stay....maybe the cause of some peoples check engine light. I bought two fel pro gaskets for $5 that fit perfect....like they were made for it. I stripped two oxygen sensors. Luckily I had a die that was the right thread. It looks like it pulled the threads out of the factory pipe. Yea yea I tried heating it and putting penetrating oil on them. No luck. Had to force them out. Pretty shitty on chevrolet's part to install them without antiseize. It was lots of fun. Still got it done in about 1.5 hours with all the trouble I had. And I changed the diff lube to Amsoil while I was under there. Having a lift made the job much easier. Why Jba couldnt have clocked the top drivers side o2 sensor a littler more to the left....I have no idea. Would have nit hit some useless tab on the trans. O well, I'll cut it off next time I'm under it. Sounds much better tho! Don't know if it gained power....but o meter says it's the same and lost some bottom end torque.
07-20-2011, 09:15 PM | #11 |
O ummm, tip: next time, install the oxygen sensors with the pipe out....then put the whole thing in....its much easier that way.
07-21-2011, 10:50 AM | #12 |
How bout I get to work this morning and some of the techs were clowning me because I used an air impact on two of the oxygen sensors to get them out. Well what they failed to disclose was the two I used an impact on were the two that DIDN'T strip out! So ha! Taking them out by hand caused them to strip in my book!
05-25-2012, 01:06 PM | #13 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
PM sent Camarowguy, i got some used too, no hardware or gaskets.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
Similar Threads | ||||
JBA Performance Headers | Mid-Pipes | Exhausts | V6/V8 | FREE S&H!!! | AJ@ECSMotorsports | V8 Bolt-Ons & Tunes | 100 | 11-13-2010 03:51 PM |
JBA Catted Mid Pipes | Tomato | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 10 | 11-10-2010 04:47 PM |
JBA non-catted mid pipes | LAYN2LOW | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 5 | 10-16-2010 09:25 PM |
JBA catted mid pipes CEL! | ducq | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 10-11-2010 08:35 AM |
Blew a JBA mid pipe gasket need help | Ronin_2SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 09-29-2010 01:02 PM |
