Old 03-06-2018, 09:46 AM   #1
Motorboy8769
Drives: 2015 2ss
7000 rpm?
I have a btr cam kit in the car .660 springs etc is it safe to spin the motor to 7000? I was told that the bottom end wouldn’t handle 7000.... any one on Here rev that high? Power starts dropping off at 6400 but I am trying to stay out of o.d
Motorboy8769 is offline   Reply With Quote
Old 03-06-2018, 10:15 AM   #2
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
I have the tsp stage 4 I shift at 6800 redline 7000 stalled auto too.
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 03-06-2018, 11:30 AM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
?...properly prepped LS3 motor can spin to 8k...all day to 7250...issue has always been valve train...did you properly shim your spring to the correct installed height for the cam?
stock cam, stock bottom end, stock clutch, stock shifter...you get the idea....mods in sig...this is honestly basic stuff...not tryin to be a smart a$$ but TONS of threads on here and the web on this..
how do I know...enjoy and good luck OP!
5k launch...7k shift...I will get it to the 11's this season if the damn track would ever open!
BTW - if the vid is blank update ur browser or click on the link to view on youtube...l8tr
Old 03-06-2018, 12:38 PM   #4
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Stock Bottom End LS3. GPI cam keeps pulling..........
BFASTNOTLAST is offline   Reply With Quote
Old 03-06-2018, 06:34 PM   #5
frankwjr
frankwjr's Avatar
ya damn tease! if that is your dyno graph...how about a little taste?
Old 03-07-2018, 01:23 AM   #6
Motorboy8769
Drives: 2015 2ss
Awesome. I’m buying the hp tuning stuff so I can adjust myself. I hit the limiter in 4th about 11-1200’ so I don’t need a whole lot
Old 03-07-2018, 08:09 AM   #7
frankwjr
frankwjr's Avatar
just take your time and enjoy the learning experience like I did..and while tough they can be hurt if drivin improperly...and be careful when playin with the nanny features..I honestly leave mine on unless at the strip..dynoSteve's remote tune relax's them just a bit but can still keep you outta trouble....peace!
btw - what have you done regarding the rear suspension? these cars already hop and with more HP ya gets more hop...trailing arms and sub-frame bushings minimum!
Old 03-07-2018, 08:40 AM   #8
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Sonofa... wow!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 03-07-2018, 08:55 AM   #9
Motorboy8769
Drives: 2015 2ss
9” rear but everything else is stock I’m not beefing it way up because I’m putting a 4 link in the back. I don’t want to spend the money twice. I have no wheel hop issues.
Here is a link to how it leaves.
https://youtu.be/sZgukAPip-g
Old 03-07-2018, 12:09 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
My shift point are around 7000. Granted I don't beat on the car all the time and I only have 38K on it.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 03-07-2018, 01:53 PM   #11
booneSS13
booneSS13's Avatar
Drives: 2013 Camaro SS LS3
What's your 1/4 mile time in that pass?
Sent from my VS988 using Tapatalk
Romans 5:8
But God demonstrates his own love for us in this: While we were still sinners, Christ died for us.
-Fastlane Cold Air Intake, NPP cat back exhaust, Stainless Works LT Headers, 2r max camshaft, Stage 3 Ported Heads (Manley Stainless steel values, titanium retainers, dual valve springs, bronze guides), Wiseco Forged Pistons, K1 Forged Rods, Clevite Bearings, Factory Crankshaft, Comp Cams rocker arm trunion kit, Morel 5315 lifters, JP performance single billet timing chain, Melling oil pump, Spec stage 3+ clutch and flywheel, BMR trailing arms, Nitto 555r 305/35/20.
booneSS13 is offline   Reply With Quote
Old 03-07-2018, 03:45 PM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
All depends on the cam, i was spinning mine to 7400rpms
62nalide is offline   Reply With Quote
Old 03-08-2018, 03:40 AM   #13
Motorboy8769
Drives: 2015 2ss
That pass was 11.76 that was before the car had a cam. It still leaves like that but runs 11.3’s - 11.4’s it has cam headers 9” CAI tune and some weight taken out of it.
Old 03-08-2018, 07:43 AM   #14
BFASTNOTLAST
Drives: 2012 SS LS3
I bet a solid 10 sec car if you can keep from turning the tire so bad on the hit!
