02-15-2019, 10:50 AM | #1 |
Got mine!
Drives: 2021 LT1 RS - Orange Crush Join Date: Mar 2011
A/C not cooling... at all
Air Conditioning not cooling at all. I heard a brief rattling sound then the A/C didn't cool what so ever. I tried replacing the refrigerant and testing the A/C clutch by jumping the connection at the fuse box as it wasn't spinning. It does engage when jumped. Replace the compressor? Condenser too? Other suggestions to troubleshoot?
Yes I know other parts of the country are freezing but I'm in San Diego. So yes even now occasionally the A/C is still needed. Any help is greatly appreciated.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
02-15-2019, 01:35 PM | #2 |
Drives: 2SS RS ABM A6 Join Date: Jun 2010
If you over-pressurized the system (or a myriad of other things), you have to disconnect the battery for a few minutes to force the ECM to reset.
Jack Bilger
02-16-2019, 11:33 AM | #3 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Sounds like a compressor.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
02-19-2019, 09:37 AM | #4 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
does your heater work properly? Does it heat up like it should or does it stay lukewarm?
Bone Stock |
