Old 02-27-2015, 02:38 PM   #1
phinsfan64
phinsfan64's Avatar
Drives: 2019 Grand Sport
Question Z06 Reproduction Rims and Tires
Please help!!!
I've found a great deal on C6 replica rims with drag radials. Am I correct in assuming that all C6 Z06 wheels fit the 5th gen Camaro SS???
The seller does not know the offset. Fronts are 18x9.5 with 255/40/18 tires and rears are 18x10.5 with 315/40/18 Nitto drag radial.
phinsfan64 is offline   Reply With Quote
Old 02-27-2015, 02:57 PM   #2
TECHTURTLE
TECHTURTLE's Avatar
Drives: 2016 Camaro 2SS
I'd skip it..
http://www.camaro5.com/forums/showthread.php?t=397813
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 02-27-2015, 05:53 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Those rears need to be +53 offset to work without a spacer.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake | Pfadt Suspension | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 03-05-2015, 09:47 AM   #4
phinsfan64
phinsfan64's Avatar
Thanks for the help. Where Is the best place to get wheel spacers and will the fronts fit without spacers?
Old 03-05-2015, 11:24 AM   #5
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
My experience is that 18x9.5, +40mm offset will need grinding on one spot of the front and a 5mm spacer with 265/50/18 tires. Might not need spacer with those tires, don't know, but the rim above will requiring of this "knuckle."
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 03-13-2015, 02:46 PM   #6
phinsfan64
phinsfan64's Avatar
The rears fit however the fronts don't come close. Is there a company that can modify the fronts to skinny's that would possibly fit? Preferably in Florida.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
