06-05-2011, 11:58 AM | #1 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
4th gen brakes, 16" rims?
After looking at crazy prices for 18+ drag tires and wheel prices and spending the day at the track. I am pretty sure a 4th gen brake swap and cheaper, smaller, better hooking wheel tire combo is the way to go! So here is my question. With a 4th gen rear brake swap, what needs to be done to get a 16" rim on.... I am thinking a 4th gen 16" rim will fit with a 28" drag slick, from what I have found is the bolt pattern is pretty much the same and should work. Would the lower control arm get in the way? Does anyone know of anyone with a 16" setup I can talk to? Thanks
10.91 at 122 H/C stock block N/A
06-05-2011, 01:30 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2010
With 5th gen V6 brakes you can run one of the 16" wheels. Either Bogarts, Welds, or CCW's will work. You can run 17's with the Brembos. The only slick available in a 17" size is the Hoosier bias ply.
06-05-2011, 03:02 PM | #3 |
Your talking big money again, I am on a tight budget thats why I asked about 4th gen brakes and 4th gen or some other cheap wheel. I can get 2 16x8s dirt cheap and a 28x10 tire ALLOT cheaper then 18" DR's. I would consider 17's too I am sure they can be found cheap as well. But I would rather have the 16" and a 275 M&H drag radial for $223 each. It would be cheaper in the long run when it comes time to replacing tires every few years also.
06-06-2011, 02:43 PM | #4 |
I think I figured it out guys, stock 17x8 GTO wheels have the same bolt pattern and range from 40-48mm back space! They should fit, over the brembo's I dont know but with a v6 brake swap they should. I am going to price out a few brake setups, I found factory GTO wheels for $50 each!
06-06-2011, 08:37 PM | #5 |
You can clear 16" wheels with V6 brakes, but you will then have control arm issues. Be prepared to do some fabrication to the arms.
06-07-2011, 07:56 AM | #6 |
Maybe the GTO 17s will fit over the brembos, I need to get my hands on a wheel.
06-08-2011, 04:17 PM | #7 |
Drives: Camaro Join Date: Apr 2009
I have a set of rear v6 brakes you can have for $150.
06-09-2011, 01:44 PM | #8 |
Drives: 2013 2ss Join Date: May 2011
so i can fit a seventeen inch wheel on my 2010 2ss?? with the brembos on??
i dont know if im reading this tread right.... |
06-09-2011, 02:16 PM | #9 |
06-09-2011, 06:24 PM | #10 |
what are the off set ?
are the wheels off the 4th gen?? please give me all the info on wheel size...... i want to do this for d/rs for my track days. |
06-09-2011, 06:48 PM | #11 | |
Im not sure on the offset but the pattern is 5x120. The wheels are not 4th gen, I don't believe those will work. They are Bogarts. If you want to run a 17" wheel you have very limited choices. It's just the three mentioned above. There maybe one more that I am forgetting. As of today, no one has found any other 17" wheel that will clear the Brembos. And it's not from a lack of looking or trying. The search has been beaten like a dead horse. They've been searching for almost two years and nothing. Sorry |
06-10-2011, 08:09 AM | #12 |
I am going to give the factory GTO 17" wheel a shot! ( same offset and bolt pattern) It may fit over the brembo's... the other issue I found is the control arm, but with a little cutting and welding that will not be a problem. I just need to get my hands on a rim.
06-10-2011, 08:35 AM | #13 | |
Good luck! If this does indeed work you will be the savior to many many C5 members. |
06-10-2011, 01:50 PM | #14 |
i already looked up the web site....THANKS
will be buying a set end of next month.. |
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
My thoughts on the 5th Gen...from a 9 year 4th Gen owner | TAG UR IT | 5th Gen Camaro SS LS LT General Discussions | 75 | 07-19-2011 09:30 PM |
So I thought I'd get a 4th gen...any advice? | Emher | 4th Generation Camaros | 19 | 07-11-2010 05:43 PM |
LS1 noob..looking to buy a 4th gen | shadow09 | 4th Generation Camaros | 45 | 06-19-2010 07:14 PM |
Coil overs for a 4th gen? | 2000v6 | Suspension / Brakes / Chassis | 2 | 03-12-2010 05:13 PM |
