Old 12-02-2018, 06:30 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Motor Mounts? To Upgrade Or Not?
I will be pulling my stock LS3 for forging in the following weeks and considering replacing my stock motor mounts with one of the three following options.
- Stock SS Motor mounts
- Stock ZL1 Motor mount
- BMR motor mounts
Would like to hear what everyone is using as well as your thoughts on the matter.
Nighthawk89 is offline   Reply With Quote
Old 12-02-2018, 06:44 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I'm about to pull my SS mounts in favor of a set ZL1 mounts stiffer then SS without the NVH of a solid mount.
Orange Krush II
Old 12-02-2018, 07:28 PM   #3
Nighthawk89
Is this the correct part number that you are aware of?
ZL1 PN - 20952437
Old 12-02-2018, 08:14 PM   #4
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I have BMR poly engine mounts. Have had them on for a while now. I wish I would have gotten the solid mount inserts instead of the poly. I can always upgrade the inserts in the future though.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 12-02-2018, 08:44 PM   #5
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Originally Posted by krisprz2010camaross View Post
I have BMR poly engine mounts. Have had them on for a while now. I wish I would have gotten the solid mount inserts instead of the poly. I can alway upgrade it in the future though.
I have the torque solution solid mounts... they are awesome. Tightened everything up nicely.
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-02-2018, 09:02 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
ZL1/Z28 mounts on mine...
-Don
747 RWHP 794 RWTQ
Old 12-02-2018, 09:24 PM   #7
Nighthawk89
-Don
Did you notice a difference Don?
Old 12-02-2018, 09:25 PM   #8
Nighthawk89
And additional noise or vibration from the mounts?
Old 12-02-2018, 09:40 PM   #9
hammdo
hammdo's Avatar
Yes, the ZL1 - Z/28 mounts were designed for track use (and the heavier supercharger in the case of the ZL1). The supercharger + lid weight 80 lbs more (vs the LS3 intake).
No noise/vibration added and zero issues - and I do track with those...
-Don
747 RWHP 794 RWTQ
Old 12-02-2018, 09:43 PM   #10
Nighthawk89
No noise/vibration added and zero issues...
-Don
Do you happen to have the PN you used?
Old 12-02-2018, 09:45 PM   #11
krisprz2010camaross
Yeah a little more vibration at idle. If you go with solid ones I’m sure that would increase the vibration noise
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 12-02-2018, 09:51 PM   #12
hammdo
hammdo's Avatar
Let me see if I can find it. GM is great @ changing part numbers ;o)
-Don
747 RWHP 794 RWTQ
Old 12-02-2018, 09:51 PM   #13
Nighthawk89
-Don
Yes. They are. I have come to find that with even some of the gaskets I’ve been looking for..
Old 12-02-2018, 10:02 PM   #14
hammdo
hammdo's Avatar
20952437
For a 2013 ZL1 or 2014 Z/28
Same part number
Special order — sometimes dealer can get it in a couple of days...
~$90 each (left/right are the same #)
https://www.rockauto.com/en/parts/ac...tor+mount,5552
Rock auto lists them @ $101..
2 year warranty too!
-Don
747 RWHP 794 RWTQ
