02-12-2019, 06:38 PM | #1 |
SoCal HT5
Sturgis Rally
Anyone going to the rally? I plan to go and wanted to see if anyone wanted to caravan up.
https://sturgiscamaro.com Rob
02-12-2019, 07:56 PM | #2 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Doubt your path will take you through Idaho, but I'm probably leaving Boise on the 25th or 26th.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
02-14-2019, 05:37 PM | #3 |
SoCal HT5
What way do you plan to go? Might be able to meet up around northern Utah
