03-05-2020, 12:30 PM | #1 |
Drives: 2016 white 1ss A8 Join Date: Jul 2016
Long tube headers
I have 2 inch speed engineering headers on my car had vbands welded to the collector and ypipe and the rest is borla mids to a awe axle back which is fully welded as one peice so the only clamp would be the vband and i have no leaks but next to walls and in tight blocks i can hear a ticking or almost like a clicking sound bouncing off things i checked the vband for leaks and have none also checked the mating surface to the heads no soot. Is this normal with headers first time driving a car with them?
03-05-2020, 12:39 PM | #2 |
Waiting for people with overpriced headers to comment "you get what you pay for" LOL my guess based off your explanation is the normal injector ticking from the LT motor. When I installed mine on my 14 Silverado I remember it being a little more pronounced.
03-05-2020, 03:52 PM | #3 |
Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
Yeah, they're pretty noisy even without leaks.
A good way to test is by pressuring up your exhaust and using a spray bottle filled with some dish soap and water. Do it with the engine and exhaust cold. Get a shop vac. Clean it and configure it to blow. Tape the nozzle into one tailpipe and seal the other (tape or a bag or latex glove or whatever). Spray the soap and water on every joint and the head. It's the easiest way I know to find leaks.
Summit White 6" Lift, 37x13.50R24's |
03-06-2020, 08:28 AM | #4 |
Yes its not a leak i went back to the shop they did that with me under the car i saw for my self and felt around the pipes for leaks no soot either just i guess its exhuast gas pulsation mixed with di and valvetrain noises haha
03-06-2020, 02:24 PM | #5 |
Drives: SS 6 speed of course Join Date: Jan 2016
I have Borla mids, IMO, this is not a Borla issue, it is an issue with anything that replaces the two small flex joints in the system. My exhaust does vibrate now, sometimes at idle I can hear the rear rubber hangers making noise as the flex. I kind of knew it was going to happen and will weld in at least one flex joint. Without at least one we are talking about a rigid system from engine to tailpipe, hence the factory put in two flex joints. So this is any issue with any aftermarket system that starts or has pipes that replace the factory twin flex joints.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
03-06-2020, 04:54 PM | #6 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I installed kooks and same thing I hear a ticking, I think its just the nature of the beast. On a side note, theres alot of rattling coming from my motor, like npp rattle but up front. I think it might be the stage 8 locking washers rattling as they weren't all tight. Could that be it maybe?
03-09-2020, 07:14 PM | #7 |
I dont have any locking washers its just the thin metal from the header went under the car and ran it i dont feel any leaks or see any
03-09-2020, 07:17 PM | #8 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Normal. Headers are thinner than the stock manifolds. You are hearing either the exhaust pulses or the thinner metal expanding and contracting.
2018 Camaro ZL1 1LE NFG; ARH 2” headers, catless mids, ARH full exhaust, Lingenfelter 18% lower pulley, ATI Harmonic Balancer, Roto-fab CAI, EE-catch can, TM ported TB, NX Lid, BMR strut tower brace. Aeroforce dual pod interceptor gauges. Tuned by Vengeance Racing!!! 644 HP @ 6250 rpm / 689 trq @ 3660 rpm
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
03-11-2020, 09:40 PM | #9 |
Its only at certain rpms and speed
03-12-2020, 07:58 AM | #10 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
This, I hear it with my speed engineering headers on my LS1 cammed camaro.
03-12-2020, 02:03 PM | #11 |
IMO, the removal of the two factory flex-joints with the Borla mid-pipe is the issue, you basically have a solid 1 piece exhaust, the ticking etc is caused by the exhaust expanding and vibrating. It is a potential issue with all aftermarket systems at the mid-pipe (all that I know of).
03-13-2020, 06:40 PM | #12 |
did you check to see if the exhaust is hitting anything. check hot it expands.
