08-21-2021, 09:41 PM | #1 |
Drives: 12 camaro ss Join Date: Apr 2016
Boost cam noob
New to FI.. picked up this turbo cam but have no idea how well it will work with a 80mm turbo at 10psi.. gurus chime in please! Need opinions. Also for pushrods will the clearance need to be measured prior to order? Plan on doing this myself and this would be my first time. TIA
Sent from my iPhone using Tapatalk Last edited by nonstopper3; 08-21-2021 at 10:06 PM. |
08-22-2021, 06:48 AM | #2 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Send it. From what I’ve been told, it’s always good to measure.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
08-23-2021, 09:10 AM | #3 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
grab a pushrod length measuring tool they are cheap. BTR knows cams, have questions call them.
