03-28-2014, 10:56 AM | #1 |
Drives: ss beast Join Date: Sep 2013
best ls3 vavle spring kit
What's up guys I am looking to buy some vavle springs kit what do you guys recommend thanks by the way I have a night fury cam
03-28-2014, 11:32 AM | #2 |
220/221 whatever it takes
Drives: See sig.... Join Date: Jun 2010
I would highly recommend getting in touch with Brian Tooley. Top notch springs.
Brent
2022 BMW X5 M50i 2022 Ram TRX 2021 GT500 CFHP 2016 Challenger Hellcat A8 1058whp/898wtq 1970 Chevelle SS396 4spd |
03-28-2014, 11:35 AM | #3 | |
Vararam Tune CAI, Vararam Power Wedge, 160 degree stat, VMax ported throttle body, Ceramic coated ARH 1 7/8" LTs with X-pipe, Borla S-Type Axle back, MGW short throw, 3.91s, Ported stock IM, BTR Stage IV cam, Heritage Grille, Backup camera, UMI Performance trailing arms and toe rods, dyno tune
03-28-2014, 11:54 AM | #4 |
Banned
Drives: ... Join Date: Dec 2013
03-28-2014, 12:12 PM | #5 |
Helping Build America
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD Join Date: Aug 2008
I use AFR 8019 springs. Installing my third set. Have had no problems with them.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
03-28-2014, 05:22 PM | #6 |
Iam hearing a lot about Brian too tooley spring
03-28-2014, 07:59 PM | #7 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
Brian Tooley platinum springs, remember the closer you are to coil bind the better. If you lift on a cam is .620 DO NOT get a .750 lift spring. Also no need for high spring pressures either.
03-28-2014, 08:03 PM | #8 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
There have been some questions about the use of PAC 1208x springs with the NFC and LS3 lifters. That seems to be a lot of spring for that combo. BT platinum springs might be a better option. Cheaper too.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-28-2014, 09:11 PM | #9 |
Banned
03-28-2014, 09:28 PM | #10 |
Drives: 2011 Camaro 2SS/RS LS3 Join Date: Apr 2013
BTR for me. Just installed my NF cam last weekend
'11 Camaro 2SS/RS LS3 M6| Black on Black| BMR Strut Brace| P&P Throttle Body| Cold Air Inductions Black CAI| 2" TSP LT Headers| Cat-Back Exhaust| Hurst Line Lock| Night Fury Cam| Brian Tooley Valvetrain| Melling 10296| C5R chain| Comp Cam rocker kit| 3.91 1LE Gear Kit| MPD1 Z Force Hood| BMR Lowering Springs| 480hp/454tq
03-28-2014, 09:40 PM | #11 |
I think it's more of a long term issue. Using a spring with a max lift of .750 will cause premature wear on the surrounding valvetrain parts. You may not see the results of that for thousands of miles. I'm sure there's someone else on here that can give a more in depth explanation.
03-29-2014, 12:10 AM | #12 | |
Search Ninja
This.
PAC springs are great springs. It's not the springs that are failing, it's the unneeded excessive pressure on the rest of the valve train. A lesser pressure spring would cause less abuse on everything else while still handling the cam lift without a problem. I don't know the max lift on the NFC, but I'd imagine it's in the .630-.640 range. A .750 max lift spring is a lot for that application. The BT platinum springs are .660 lift and $100 cheaper.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. Last edited by axis; 03-29-2014 at 12:28 AM. |
03-29-2014, 12:19 AM | #13 |
Drives: 2011 LS3 Join Date: Jan 2012
Im on the same boat I have a nf cam waiting install. The lift is 61x on both intake and exhaust, will btr 660 springs be okay? I ve been read up on all these cam failures just wanna do it right the first time around.
Stainless Works Headers Vmax TB SLP loudmouth 2 Nightfury Cam Mike Norris CC Tuned by Southwest Speed |
03-29-2014, 12:27 AM | #14 |
Search Ninja
Yes they would. They have two flavors, depending on what you want to spend. Platinum with ti retainers for $300 or with steel retainers for $220.
