Old 09-21-2022, 10:42 PM   #1
Parker3
Parker3's Avatar
Drives: 2013 Camaro 1LE
Need help with amp rack
I was wondering if anyone knew who sells or where I could get one at. Or just any other idea. I have 2 aftermarket amps need to find a spot for. Any help is appreciated thank you!
Parker3 is offline   Reply With Quote
Old 09-22-2022, 08:59 PM   #2
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
I put a board behind the back seat and covered it with trunk liner material. It works, but it closes off the trunk. Before that I used a board to mount one amp where the factory amp was and the other amp on my sub box. That worked too, but the amp in the factory location was not accessible.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
