Old 10-27-2022, 10:09 PM   #1
Koelzmod
Drives: 2013 SS Camaro
Installing Auxiliary Gauges
I am installing a Nitrous pressure gauge and looking for a place to attach the wire to light up the gauge when the lights are on. Can anyone tell me where or what wire to tap into to light up the gauge?
Koelzmod is offline   Reply With Quote
Old 10-28-2022, 07:58 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
The fuse box is on the driver's side of the dash. There is switched fuse in the middle that I use to power a few things. Some guys like to wire into the dash lighting so it will dim with the dash lights, but I don't have time for all that. I wired my nitrous gauge light into the arming circuit, so the gauge light only comes on when the system is armed. I did this because I use remote control switches rather than having a bunch of switches in the cockpit and that is confirmation the system is arming properly.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 10-28-2022, 09:07 PM   #3
Koelzmod
I see you're located in Palm Bay. You're not far from me. Today I found a 2 amp circuit in the fuse box that you mentioned. it's only hot with the key on. So I tapped into that. Thanks for the help.
