03-01-2017, 03:14 PM | #1 |
Drives: Hyper Blue 16' M6 1ss Join Date: Dec 2015
Taking car to the track Friday. What to expect? (Full bolt ons + e85 M6)
What times and MPH should i expect?
Weather will be 65 degrees, 50 percent humidity and the track is near sea level (royal purple raceway, Baytown Tx) Mods are 2" headers+ high flow cats, rotofab cai , MSD Intake, E85 with tune, Nitto 555r drag radials, Stock non Npp cutback and M6. Again any guesses or estimates? |
03-01-2017, 03:25 PM | #2 |
60' 1.8
ET 11.8 MPH 117 That's my guess, sounds like a good day to run
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
03-01-2017, 04:10 PM | #3 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
11.95@117 if you can get your 60ft in the 1.90's. If 1.80's in the 11.80's. Good luck
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
03-01-2017, 05:00 PM | #4 |
OP, same exact setup here except 1 7/8 LTs including the Nitto DRs minus E85. I was stuck in the 12.4s, with an occasional 12.3 stock.
My first outing with the new setup was a high 11.9 @118 with a very high 1.9 60'. With 30 more HP you should see 11.7-8s @ 120 in good air and a 2.0 60'.
"Democracy Dies in Darkness" |
03-01-2017, 06:28 PM | #5 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
11.6 - 11.7 if you do your part behind the wheel.
03-02-2017, 12:06 AM | #6 |
Drives: 2017 1SS Join Date: Mar 2016
Focus on a good launch and the numbers will follow, no lift shift will give you an edge too. Enjoy the new mods!!
60' 1.7-1.9 1/4 11.6 - 11.8 117-119 |
03-02-2017, 12:53 PM | #7 |
With the OPs NT 555Rs 1.7s can be very rare and 1.8s even tricky. But they are pretty safe in the rain and can last 2x over the better rubber. The every day DR, just not in the winter in cold climates.
03-02-2017, 01:53 PM | #8 |
Da will be 0 to -200. I am nervous about launching hard and breaking something.
03-02-2017, 05:46 PM | #9 | |
So no worries. Track mode TC off. On NT555Rs my best times are after a nice burnout. Then do a 2000-2500 RPM launch with a smooth clutch release feeding as much throttle as the tires will take with only a light spin. It is much harder than it sounds. I do best when I don't over think it. The third green light is when you start releasing the clutch. People say don't worry about the RT, but for me I try to launch exactly the same each time. Some nights all of my 60s are within a tenth of each other. I am not super good at it but at least can be consistent. If you hook you might start getting wheelhop. That is when things start breaking even with so-so tires like the NT555Rs. On a good DA night when my stock SS M6 was dipping in the 12.3s I went home, the wheelhop was getting so bad. If you feel/hear the bang back off right away. I added upper and lower BMR Trailing Arms and Upper Control Arms. Wheelhop problem solved. Go for it and let us know how it goes!
03-02-2017, 10:34 PM | #10 | |
03-02-2017, 10:46 PM | #11 |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
Excellent advice by Fraxum.
OP how did it go? My guess, With a 2.0 60, 11.8-11.9 With a 1.9 60, 11.6-11.8 |
03-03-2017, 12:47 AM | #12 |
Im going friday night
03-03-2017, 09:09 AM | #13 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Good luck tonight, drive it like you stole it
H/C SBE 9.80@140 powered by Texas Speed
03-03-2017, 09:41 AM | #14 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
How'd you do?
I kid... good luck tonight!
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
Thread Tools | |
