Old 06-07-2017, 10:29 PM   #1
lt4camaro
Drives: 2016 1lt v6 manual
OIL PUMP ISSUES, OIL IN THE BRAKE BOOSTER
ANY ONE HEARD OF THIS RARE CONDITION? BRAKE HISS NOISE, AIR LEAK (BOOSTER NOISE) CAN BE HEARD INSIDE THE CAR. WITH IN A DAY OR TWO NOTICED BRAKE PEDAL GETS HARD AND FINALLY NO BOOSTER ACTION AT ALL, HARD PEDAL ALL THE TIME. LAST YOU GET A BRAKE ASSIST WARNING AND FINALLY A CHECK ENGINE LIGHT. PULLED CODES, IST CODE, LEAN ON BANK ONE, AND 2ND CODE LEAN ON BANK 2.
TOOK CAR TO DEALER,DEALER FINDS BOOSTER HALF FULL OF OIL, CAR HAS ONLY 500 MILE'S ,IS A 2016 CAR. SERVICE DEPT RESEARCH THE BRAKE HISS NOISE AND HARD PEDAL, THEY COME UP WITH A TSB # 17-NA-21.
THE FIX IS REPLACE ENGINE OIL PUMP, REPLACE VAC HOSE TO BOOSTER AND REPLACE BOOSTER. DEALER HAS NEVER SEEN THIS BEFORE AND THEY ARE A HIGH VOLUMN DEALER. I AM TRYING TO FIND OUT WHAT WAS WRONG WITH THE OIL PUMP.
lt4camaro is offline   Reply With Quote
Old 06-08-2017, 09:14 AM   #2
DvKillar
DvKillar's Avatar
Drives: 2015 Chevy Camaro 2LS
is that a 4, 6, or 8?
DvKillar is offline   Reply With Quote
Old 06-08-2017, 09:32 AM   #3
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
The dealer is saying that there is oil somehow getting into the brake booster through a vacuum line?
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
Old 06-08-2017, 10:25 PM   #4
lt4camaro
3.6 v6
Old 06-08-2017, 10:32 PM   #5
lt4camaro
THATS CORRECT, THE ONLY THING I CAN THINK OF IS OIL IS GETTING INTO THE INTAKE NEAR THE BOOSTER VAC LINE CONNECTION AND OIL GETS INTO THE BOOSTER. I ASSUME IT HAS TO BE A PRESSURE ISSUE WITH THE PUMP AND IT MUST BLOW THRU SOME SORT OF SEAL IN THE INTAKE. THE OIL PUMP IS THE FAILED / DEFECTIVE/ PART MAKES TO MUCH PRESSURE??, WHAT ELSE COULD IT BE DOING WRONG?
Old 06-09-2017, 07:12 AM   #6
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Turn off the damn caps key . Jesus.
So are they fixing your car under the TSB? Which I would assume they are ,plus your car is under warranty . This should have been posted in the GEN 6 forum. The Gen 5'S use either LLT or LFX engine not the LGX like your car uses.
I'm going to assume that this has happened enough that they created a TSB about it which your car falls under.
I'm not trying to be an ass. But I don't understand what your trying to get at here .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 06-10-2017, 01:05 AM   #7
DokWatson
Dok
DokWatson's Avatar
Drives: 2015 Camaro 1LS M6
Can you post the actual TSB? Google didn't show anything. I want to know how the hell an oil pump puts oil into the brake booster.
Hoonigan/Technician
Check out my channel.
https://www.youtube.com/user/AK49Watson
DokWatson is offline   Reply With Quote
Old 06-10-2017, 02:48 PM   #8
lt4camaro
Just trying to inform people on the 6th gen V6, and to see just how uncommon this is. Of course the car was fixed at a dealer and was a warrantee claim . Got a new 17 cruze for a loaner, I was treated well.
Old 06-10-2017, 02:57 PM   #9
lt4camaro
I could not find any thing either, dealer says they were not able to print it out for me. I will attach what I have.
Old 06-10-2017, 05:01 PM   #10
1Coopgt
1Coopgt's Avatar
I don't get it . How does changing the oil pump fix the problem? Glad you got it fixed. Hope you also posted this in the Gen6 section.
Old 08-17-2017, 11:23 AM   #11
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
I'd imagine there's a diverter valve in the pump assembly that when not working properly sends pressurized oil up the vac line. 22 hour repair- not fun.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
