07-05-2018, 05:23 PM | #1 |
Drives: 2010 camaro ss Join Date: Nov 2017
E85/supercharger question
Soo i have a ecs novi 1500 on the way with 80lb injectors . Currently cammed , no cats , long tubes , port/ polished rod mod / throttlebody zl1 pump / adm fpcm/ 475 whp / - thinking of going e85 flex fuel - will my current fuel set up handle it or will i be about maxed out . What kind of whp can i support ?
07-05-2018, 05:26 PM | #2 |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
600 to 650ish on 93 oct
Sent from my SM-N950U using Tapatalk |
07-05-2018, 05:28 PM | #3 |
May squeeze 700 out of it but it just a bandage, add a external aux fuel pump and a pressure switch or buy a dual pump system
07-06-2018, 08:07 AM | #4 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
+1 for Hou30guy.
You'll be happy with your setup for about 6 months tops, then you'll want to pulley down for more boost and hp. Give yourself room for growth on the front end so you don't buy stuff twice...or three times...
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
07-06-2018, 08:48 AM | #5 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Do the fuel now, get a twin in-tank setup. AGP / Squash / and Fore all seem to be reputable systems around here. I am running the squash dual 450 Walbro with the second pump coming on with a 2psi hobbs switch. Running E-85 flex fuel setup and ID-1700s.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
07-06-2018, 09:07 AM | #6 |
Getting a aux pump and plum it with the zl1 pump will be the cheapest and just as good as a twin pump setup
