10-09-2011, 10:16 AM | #1 |
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT Join Date: Jun 2009
E85 FUEL
Did a search on here and on line. And have found a lot of good info on the E85 fuel. I seen where some people are usin it. What I do not understand. How does the V6 camaro run on E85 fuel? What has to be done to the car, for it to run on E85?
Retired |
10-09-2011, 11:26 AM | #2 |
SOCAL HT5
all i know is that i asked Vince to tune my engine for me so he did and now it runs on it haha.
2013 ZL1 M6 - Mods-in the works
Old vehicles 2010 CGM Camaro (sold) Other Vehicles: 2008 Kawasaki ZX6R-115 RWHP in mid summer 2006 Chevy Trailblazer SS- For Sale; Lots of extras |
10-09-2011, 01:13 PM | #3 |
Drives: 2012 Camaro M6 2LT Join Date: Sep 2011
I was wondering if anyone knows weather the 2012 camaro v6 can run it stock, since the impla is running the LFX engine as well and it's e85 capable.
10-09-2011, 01:51 PM | #4 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Don't take that as a bad thing though....I'd guess tuning for more E85 power in the 2012 would be easier. Nobody has done it yet though.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
10-09-2011, 03:13 PM | #5 |
crazier than a coconut
Drives: 2010 2SS/RS LS3 Join Date: Jul 2010
what are the negative side effects of running E85 on a non 2012 V6?
10-09-2011, 03:52 PM | #6 |
Drives: jealous vendors mad!! HAHA!! Join Date: Jan 2011
2012 LFX engines are e85 capable from factory and you guys have the advantage over non e85 capable LLT. If you have the new LFX and want to take full advantrage of e85 I would talk to vince and get him to tune the e85 side of things asap. You have no idea what you are missing
Me and vince already did a full testing on e85 on our LLT and I ran 13.5 with it and usa1 13.6 in 1/4 mile. I also pulled 284 std and 291 ASE corrected on the dyno and this was with factory intake. The wonderful thing about it is that there's so much room for even better performance. http://camaro5.com/forums/showthread.php?t=153071 If you are asking what type of negative effect it has running 85% ethanol on non flex fuel vehicle you are going to get 1001 different opinion. I personally don't think you are going to see any problem over the time you are going to own your camaro running e85. They had a poll over at evo forum on the longest e85 usage and the longest was going on 3 years of daily usage with zero problems. If you do a search you will get your answer on the web. I have to tell you guys this, but unfortunately if you have hypertech you won't be able to run e85. At this time vince is the only guy who will write a e85 tune for you. |
10-09-2011, 04:30 PM | #7 |
Thanks for the info. Been kinda of a pain to get any info from like the dealer on weather it would just run on it. Will tune it later on down the road but thanks for the answer to my question ^-^
10-09-2011, 05:05 PM | #8 |
thanks bmore. i think im gonna give E85 a shot and see what results i get on the dyno. this is going to be fun
10-09-2011, 11:29 PM | #9 |
by the way, are you still running with E85?
03-08-2012, 02:14 PM | #10 |
Always drop the top
Drives: 2014 Stingray Vert 2LT z51 Join Date: Feb 2012
Does the e85 tune just for power? I have the LFX, and put in e85 today, engine seems to run fine, i'm doing all city today so my mpg sucks. Also didn't know if it take a few on/off for the air fuel mixture to adjust.
But I'm moving to FL where there is about 0 e85 stations, I'm in MN now where it's $.60/gal cheaper that regular. So I don't need an e85 only tune given my move in 3 months. Do the e85 tunes Vince does have options? Like you can switch between an 89 tune, 91, and e85? I know some tunes on Audi's let you change on the stalk between tunes. |
03-08-2012, 02:26 PM | #11 | |
But if the stock tune can handle E85 like it does on the impala you will be fine. I guess if your car continues to run fine, that could be the case but until it is confirmed you had better put gas back in. Someone please correct me if I am wrong here.
03-08-2012, 02:27 PM | #12 |
That said, If a stock E85 tune does exist, I'm sure that it does not really increase power much, if any. Letting vince alter the E85 tune would yield more power for sure.
03-08-2012, 02:29 PM | #13 |
E85 does add power due to its natural characteristics. not sure how the LFX will respond to E85, but my guess is that it will take you another fill up before you really feel the change. right now your running a mixture of gas/ethanol with throws your fuel tables/air/timing off. the ECU will adjust for it, but until your ECU reads nothing but E85 is when i believe you'll really feel the effects of it. but, i could be wrong.
as of right now, he isn't providing octane specific tunes for gas, but there is a project currently in the works. and no, he doesn't provide options for E85 which would account for minimum ethanol levels of 70% or lower. the E85 tune is exactly that...a tune for 85% ethanol. im sure he could give you a tune for different ethanol levels, but that would require some data logging and more $$$ since it won't be free. for somebody else (since your moving) with the 2012, it might be worth your time and look into an E85 tune since its already compatible.
03-08-2012, 02:33 PM | #14 |
Drives: ELLE-1 Join Date: Jul 2011
the cost of e85 to miles per gallon does not make sense..... 50 or 60 cents cheaper, really......on a v-6 you might get 19 miles per gallon on highway.....on straight 92 octane i get 31 MPG.....and ive only seen E85 for about 20 or 30 cents cheaper...ok i saved 4 bucks on 15 gallons with E85 and got a tank full of corn fillers....just buy the good stuff and get good gas MPG and stop worrying about weather your cars going to have problems down the road....there going to quit making E85 anyway.....
http://www.cars.com/go/advice/Story....lAlt&story=e85 |
Similar Threads | ||||
Fuel: getting it right the first time | S-eatin-grin | Forced Induction - V8 | 45 | 08-30-2012 01:22 PM |
Acronyms at C5 | hokie2012 | 5th Gen Camaro SS LS LT General Discussions | 34 | 08-10-2011 03:56 PM |
JRE FUEL SYSTEM UPGRADE EDELBROCK SUPERCHARGERS | JANNETTYRACING | Forced Induction - V8 | 91 | 05-11-2011 10:35 AM |
Why you should never let your wife take your ss | BIGSWOLE | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 54 | 05-07-2011 12:42 PM |
Lethal Performance/ Fore Precision Fuel Hats- CHECK THIS THING OUT | Jared@Lethal | Forced Induction | 3 | 08-12-2010 11:30 AM |
