Old 07-13-2014, 06:29 PM   #1
#1stunner
#1stunner's Avatar
Drives: 2011 syn. green ls
noise in the rear...help
The other day leaving work I hit a small pothole on the back drivers side and I heard a noise .it sounded like one of my exhaust clamps were lose.I checked everything I could see and went over every bolt I could get a socket on,and still have the noise.checked the battery also.it's all tight.kinda sounds like two washers rattling around.any ideas?thanks for any input
#1stunner is offline   Reply With Quote
Old 07-14-2014, 05:02 AM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Check the rear deck speaker, are those nuts tight? Check the rear spoiler if you have one to make sure that is tight too. Then look at all suspension bolts and just check for tightness.
Old 07-14-2014, 05:29 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
I think the most common cause of noise in the rear suspension is the sway bar endlink. It connects the bar to the lower control arm.
If it's loose, hold the center with an Allen wrench and tighten the nut to 36lb/ft.
Old 07-14-2014, 06:40 PM   #4
#1stunner
#1stunner's Avatar
I didn't check that,I don't have a spoiler,and I checked the speakers,there good.it's def.something under the car in the rear.getting ' very p.o with this noise.I haven't had these struts out yet.is there anything on the top of the strut that could come lose?thanks in advance
Old 07-14-2014, 07:03 PM   #5
rtcat600man
Have you put the car in the air as in changing or rotating the tires? I noticed when I rotate my tires that when the springs are hanging (I am lowered too by the way), the rubber mount in the rear that is on the top of the spring, needs to be tucked back into the spring, and I often wondered if that was one of the squeaks I have heard before.
Old 07-14-2014, 08:23 PM   #6
#1stunner
#1stunner's Avatar
i seen the rubber peice your talking about,it looks fine but ill check it out tomorrow.
Old 07-15-2014, 05:54 PM   #7
#1stunner
#1stunner's Avatar
somehow today going to work the noise just stoped.knock on wood it doesnt return,but im assuming something worked its way lose and just fell out of whereever it was stuck at. i checked everything again tonight and all seems well.idk.thanks for the advise though
