Old 11-14-2014, 04:20 PM   #1
Vick415
Vick415's Avatar
Drives: 2014 ZL1
Talking **Vick's 830RWHP - A6 - ZL1 Build**
Update: 4-27-2015
Okay so I have updated this post due to new dyno results based on few more tweaks and 97 Octane run; Dyno results posted below (#15)
__________________________________________________ _______________________________
Update: 11-14-2014
She finally returned home yesterday after a well deserved performance upgrade.
Mods: (short list)
Trick flow heads, and custom cam. Upgraded pushrods & lifters along w/rocker bearings. Upgraded balancer for more boost. Injectors with a full ARH system. Full port job with a 91-octane Tune!
Before and after:
Name:  Fullscreen capture 11142014 92625 AM.bmp.jpg
____
Prior to this upgrade it had a CAI, pulleys along with a tune (as shown in graph above). Approx. 184 gain from previous, overall 230 RWHP gain since it rolled out of the dealership
More to come:
Methanol injection system will be next
____________
Short Idle Clip:
ARH w/X-Pipes & High Flow cats w/Stock mufflers - NPP wide open
Vick415 is offline   Reply With Quote
Old 11-14-2014, 04:21 PM   #2
SSCam99
SSCam99's Avatar
Drives: 2019 Camaro ZL1
That is awesome. Congrats!
SSCam99 is offline   Reply With Quote
Old 11-14-2014, 09:12 PM   #3
MaxxMuscle
Blanchard Performance
MaxxMuscle's Avatar
Drives: 2014 Black ZL1
Great #'s bro.
MaxxMuscle is offline   Reply With Quote
Old 11-14-2014, 09:18 PM   #4
TXISKING
TXISKING's Avatar
Drives: '13 ZL1 725 rwhp / 700 ft lb tq
Glad it finally finished. You will enjoy that power.
'13 Black Manual trans , Heads, Cam, Injectors, Ported Snout, Vmax throttle body, RotoFab, Headers, No Cats, 9.55 lower pulley, D3PE heat exchanger, - 725 rwhp/700 tq
TXISKING is offline   Reply With Quote
Old 11-14-2014, 10:03 PM   #5
blk13
Drives: 2013 zl1
How much power do you think the ported trick flow heads are giving you? Ive heard around 30 horse gain on worked stock heads, curious what the worked TF do!
blk13 is offline   Reply With Quote
Old 11-15-2014, 06:09 AM   #6
big dave
Drives: 2017 ZL1
Great numbers! Man, that thing's gonna fly!
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 11-15-2014, 06:32 AM   #7
Splitter
Drives: '14 RRM 1LT/RS A6
Keep it straight so you keep it in one piece!
Splitter is offline   Reply With Quote
Old 11-15-2014, 08:06 AM   #8
white ZL1
Drives: none
What are the cam specs?
What kind of dyno was it?
white ZL1 is offline   Reply With Quote
Old 11-15-2014, 09:45 AM   #9
charlietuna
charlietuna's Avatar
Drives: 2013 ZL1
strong numbers !!
Laus Deo
charlietuna is offline   Reply With Quote
Old 11-15-2014, 10:14 AM   #10
Vick415
Vick415's Avatar
Drives: 2014 ZL1
Your guess would be as good as mine at this point since the heads were installed along with all other mods prior to Dyno/Tune. 30HP would be a good guess however would depend on how much boost you are making along with few other variables. Overall for me it was about reliability during its lifecycle and future goals (more HP!) so TF was the obvious decision in this case.
Sent from my iPad using Tapatalk
Old 11-15-2014, 01:36 PM   #11
Vick415
Vick415's Avatar
Drives: 2014 ZL1
Originally Posted by MaxxMuscle View Post
Great #'s bro.
Originally Posted by charlietuna View Post
strong numbers !!
Thank you !
Old 11-15-2014, 05:03 PM   #12
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Outstanding!!! Very solid build and perfect numbers.
Can't wait to see what it traps...
Old 11-16-2014, 05:39 PM   #13
Vick415
Vick415's Avatar
Drives: 2014 ZL1
You read my mind! I plan on taking her to the strip next week. Should be comical attempting to gain traction on stock tires!
Old 11-16-2014, 05:58 PM   #14
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Ha Ha... I haven't even tried. Been there done that when it was stock. No way I'm going back until I have some MT's on the rear.
I have hit the road track a few times and going again in two weeks. PTM modes are your friend there. Turned them off and it got scary fast. LOL
700rwhp a6 zl1 lsa, 850hp zl, zl1 build
