03-24-2015, 05:52 PM | #1 |
Drives: 2014 Blue Ray Metallic 2LT/RS Join Date: Jan 2015
CAI install now check engine light
I just installed a CAI unit on my 2014 3.6 with 9k miles. I drove approximately 15 miles and check engine light came on. Oil level and pressure all report good per gauges.
Anyone else have this problem or suggestions of what could be problem? Thanks Mike
2014 2LT / RS Blue Ray Metallic, 6spd, Tinted windows, painted calipers, 1LE frt/rr rock guards, NPP exhaust (fuse pulled), CAI intake, Elite E2 Catch can, Vitesse throttle controller
03-24-2015, 05:55 PM | #2 |
Have you checked the codes? What are they?
03-24-2015, 06:00 PM | #3 |
Do somethin fun every day
Air sensor put in backwards?
03-24-2015, 06:12 PM | #4 |
Drives: 2013 1ls inferno orange camaro Join Date: Oct 2013
Disconnect battery, touch leads together, and hook back up
03-24-2015, 06:59 PM | #5 |
make sure all the hoses are attached properly and clamps tight. there is a small hose that should have been reconnected to the new intake. MAF (Mass Air Flow sensor) could be dirty, did you put your dirty fingers on it? if so you will need to go to an auto parts store and get some MAF cleaner. clean and then be careful not to touch the part of the sensor that sits in the tube. if none of that helps, get the codes from an auto parts store that will read your codes for free. |
03-24-2015, 07:36 PM | #6 |
Thanks for all the suggestions. I will get the codes checked tomorrow during lunch.
The air sensor housing can only install one way in CAI pipe. I thought that the sensor itself could only snap on one direction. I will have to double check that. gmfm86 what exactly do you mean by "touch the leads together"? I don't want to fry my air sensor or any other electronic board. I didn't even get my hands dirty doing the swap last night as the engine area looks like it hasn't even been driven. I'm not sure I could have got the sensor dirty but I will look at codes and possibly clean tomorrow just as a precaution. Will the check engine light go off if problem is fixed or does it have to be reset in some manner. I'm a little worried as this was my first mod and it was suppose to be a "plug n play". Worked really nice last night and on my drive to work today but then on the drive to home just cruising at highway speeds (70mph) the light came on. I appreciate all your input. I will let you know if I find any direct contributing factor. BTW....does the CAI intake unit mess with warranty? In other words, will I have to reinstall my stock unit to take it in to dealer for service if necessary? Thanks again,
03-24-2015, 09:06 PM | #7 |
Texas HT5
Drives: IBM Join Date: Oct 2012
Yes swap it out before you take it in, even autozone can read the codes for you to clear it, you can unplug you battery in your trunk and let it sit a few minutes the code won't be there see if it comes back
03-24-2015, 09:20 PM | #8 |
Drives: 2011 2SS/RS LS3 Join Date: Jan 2015
dude buy a code reader, you can get a bluetooth one that connects to your phone for like $40 these days. I can't believe everyone doesn't own one yet.
03-24-2015, 10:11 PM | #9 |
Drives: 2014 Camaro 1LS Join Date: Jul 2008
The intake is fine, won't mess with your warranty.
1981 Camaro Z28 (SOLD), 1987 Camaro (SOLD)
2000 Camaro (SOLD), 2002 Camaro Z28 (SOLD) ----------------- 2014 Camaro ----------------------- |
03-25-2015, 06:20 AM | #10 |
Drives: 2016 1SS SW Join Date: Jun 2013
Touching the leads together wouldn't do anything if they're disconnected from the battery. You probably just have a little air slipping through somewhere. If you're gonna do more performance mods it'll help to have your own code reader. This also gives you a little leg up on your mechanic when you bring the car in and tell them to investigate the specific code rather than "I don't know what it's doin just fix it". The autozone code reader can also clear the code for you, so no worries there. Your car is fine, I've never been more sure about anything before in my entire life.
03-25-2015, 08:45 AM | #11 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
If you didn't disconnect the negative from the battery before install, it is possible that the fuel trims went outside of the allowable parameters during adjusting to the CAI, and it threw a code during the relearn process. Clear the code, disconnect the battery negative for about 30 minutes, and then see what happens. This is why it is in the instructions to disconnect the negative before installing the CAI. The only other thing to check would be that all the connections are on tightly and correctly.
03-25-2015, 02:27 PM | #12 |
I had the codes read at lunch today. It came back as "random cylinder misfire". After hearing this I opened the hood to check things like plug wires, hoses , clamps,etc. I noticed that I didn't snap the red clip into place on the air sensor for the CAI. It want loose but maybe with engine torquing or hitting bumps in road it caused an electronic hiccup that threw the code. It has been reset and I will monitor for the next couple days hoping that it won't come back.
Thanks again for all the advice and support.
03-25-2015, 02:34 PM | #13 | |
