Old 09-28-2017, 09:56 PM   #1
YoungCamaroHopeful
YoungCamaroHopeful's Avatar
Drives: Black 2010 1LT w/ SS nose
How would you mod with only $400
If you had a stock 2010 1LT and $400 to spend on mods what would get?
YoungCamaroHopeful is offline   Reply With Quote
Old 09-28-2017, 10:12 PM   #2
briancamaross
briancamaross's Avatar
Drives: 2011 ss 2ss auto camaro
Well to be honest a varram cold air intake is about all you can do beside a under drive pulley,with out needing a tune. If you can save up more money get headers, tune and be good to go.If you can really save up do the varram cai and headers and tune you will gain a lot more power. Just do what you can afford.
2011 2ss white Camaro mods are texas speed stage 4 cam 235/239 Texas speed 2inch headers no cats magna flow bullet mufflers gpi rod mod ,circle d 4000-4200 5c stall. 3.91 gears vararm cai power wedge.
briancamaross is offline   Reply With Quote
Old 09-28-2017, 10:24 PM   #3
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
Best advise you can get right here. Vararam cold air intake.
Talladega is offline   Reply With Quote
Old 09-29-2017, 05:00 AM   #4
Starfall
1bad6
Starfall's Avatar
Drives: 2010 camaro
Vitesse throttle controler, cold air intake, headers, trifecta
Starfall is offline   Reply With Quote
Old 09-29-2017, 05:17 AM   #5
gringo
gringo's Avatar
Drives: Camaro V6
I'd address the timing chain issues before doing anything else.
gringo is offline   Reply With Quote
Old 09-29-2017, 06:50 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
longevity mods being that your in a 7 year old v-6, catch can if not equipped, timing. engine cleaning internals..all maintentance as your most likely not looking for exterior all show mods. Or save to down pay a newer SS.
Old 09-29-2017, 07:20 AM   #7
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Good advise, IMO. If that's all you have to spend, put it toward the balance or maintenance.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 09-29-2017, 08:29 AM   #8
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Agreed ^^^
Don't start down the path of modding your car if all you can swing is $400. Its a slippery slope once you get the ball rolling
Hixson is offline   Reply With Quote
Old 09-29-2017, 09:00 AM   #9
myold88
myold88's Avatar
Originally Posted by Hixson View Post
Agreed ^^^
You guys are nicer than me. I was going to tell the OP to open a savings acct.
Old 09-29-2017, 09:24 AM   #10
MrChrisLS3
Drives: 2018 1SS M6
I will add that if this is your daily, especially if it's your only car, keep in mind that almost every modification you make may reduce reliability just a little bit. Not all, but some.
Also keep in mind that many of the parts you need for simple maintenance are a little more expensive and labor intensive than a lot of the "normal" cars out there.
Someone mentioned a catch can. For a direct injected engine like yours, this is a big benefit as they tend to have carbon build up, or "coking" issues on the valves. At this point, it's probably already there, but a catch can will slow it from getting any worse.
Oil...this is huge on the VVT engines. Don't let the oil life monitor get down to 10%. These things have a way of making oil magically disappear.
Then there's things like spark plugs, coil packs. In order to change these out, it requires lifting the intake manifold, so that will require new gaskets. If you don't do it yourself, there's your $400 right there.
So, you see where I'm going with this. Not bagging on you for having a tight budget at all, I do too. The point is to keep the thing properly maintained and put off the "go fast" stuff until you're in better position to do so.
MrChrisLS3 is offline   Reply With Quote
Old 09-29-2017, 10:28 AM   #11
jrhagen
Banned
Drives: Camaro
Make an extra car payment.
jrhagen is offline   Reply With Quote
Old 09-29-2017, 10:28 AM   #12
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
lowering springs and intake?
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 09-29-2017, 03:46 PM   #13
TooManyProjects
Drives: 2012 Camaro 2ss
Get a civic
TooManyProjects is offline   Reply With Quote
Old 09-29-2017, 04:27 PM   #14
Spurshot
Drives: 2014 2SS blue
Put $400 worth of gas in it and drive it for pleasure.
Spurshot is offline   Reply With Quote
