Old 04-02-2018, 12:50 AM   #1
jcaligood
jcaligood's Avatar
Drives: '18 SS 1LE
Dropping oil pan?
I'm replacing my oil pump, due to lost oil pressure.
First step is to remove oil pan bolts, which i have done from under the car. Have not taken the timing cover off yet.
All oil pan bolts from underneath the car are removed, but the oil pan will not drop. Wont even budge.
Am i missing something here? Are there any bolts behind the oil pump that i need to remove?
Can't seem to get this damn oil pan to drop.
Any help or suggestions are greatly appreciated. Thank you!
jcaligood is offline   Reply With Quote
Old 04-02-2018, 08:56 AM   #2
Waremaster
Drives: 2013 Camaro
It seems like the pan is stuck to the gasket material.
If you are positive you have removed all of the bolts you may try hitting the pan with a rubber mallet and see if that frees it. Otherwise you may need to gently separate the pan from the block with a flat blade screwdriver or something similar by going at the seam in a few places. It should drop after that.
Waremaster is offline   Reply With Quote
Old 04-02-2018, 09:10 AM   #3
Synner
Drives: cars
Loosen the starter bolts. It hangs on the lip and won't let it drop. There's also 2 on the front cover that tie into pan.
Old 04-02-2018, 10:33 AM   #4
RS111341
RS111341's Avatar
Drives: 2011 SS IOM auto
2 15mm socket head bolts in the bell housing? Or is that on the autos only?
RS111341 is offline   Reply With Quote
