12-24-2014, 03:44 PM | #1 |
Drives: 2014 Camaro 2SS in Blue Ray Metalic Join Date: Aug 2014
Need an Electrical Consultation
Hoping one from the Camaro Experts on here can help me with this. I'm looking for a 12vdc wire I can tap into that is controlled by the light sensor on the dash? All I keep finding are wires with just under 5vdc, I need 12vdc. Does what I'm looking for exist inside the car and if so, where is it??
Thanks..... |
12-24-2014, 03:51 PM | #2 |
you could always tap into the headlights, since they turn on by the sensor? I imagine you are trying to wire lights up to come on when it get darker out?
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
12-24-2014, 04:37 PM | #3 |
Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
Are you looking for just 12v, or are you looking for lights that dim at night?
12-24-2014, 06:02 PM | #4 |
I installed the Diode Dynamics LED Cup Holder inserts in my SS, they run off 12VDC. I would love to hook them up so they come on at the same time the ABL lights do. I know the ABL light are controlled by the light sensor. Being able to dim them isn't all that important to me.
http://www.diodedynamics.com/store/a...holder-inserts |
12-24-2014, 06:36 PM | #5 |
Light sensor doesn't have 12VDC from what I see in wiring diagrams. but if you need 12VDC you could like I said tap into the headlights, or interior Dash/Center Console Lights, These will turn on if you manually have lights on or also if set to auto they will come on when the light sensor tells the interior lights to kick on.
Modifications
12-24-2014, 09:58 PM | #6 |
First of all LED'S work on current not Voltage, you want approx 40ma going through the led's . If you bought this kit for the car, then it probably has a res. to limit the current and is made for 12V. You can get the 12V from the 12V Pwr connector in the Arm Rest
12-24-2014, 10:44 PM | #7 | ||
Modifications
12-24-2014, 11:03 PM | #8 |
no, he wants them to dim and work just like the abl lights on the door. they only come on somewhere halfway through the range and get brighter
Typing fat fingered on my GS3...excuse any sfelling mitcakes
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars '94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A -- >> Some of my Projects My Fquick Page |
12-25-2014, 08:04 AM | #9 | |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
Different color leds are different voltages. A resistor must always be used in series with leds TO LIMIT THE CURRENT. The formula for figuring out the resistor is as follows: R=supply voltage -Led voltage/LED current If the resistor is not a standard value always choose the next bigger size. |
12-25-2014, 12:40 PM | #10 | |
Volt source 12/15V - LED volt. (2-3V) = 10-12V, div by led current (30-40ma) =resistor value (approx 300 ohms) |
12-25-2014, 03:54 PM | #11 |
Sorry Comrando, I'm with Gutterball and Rainbow.
As far as the question about where to tap a source, I connected my cupholder lighting to the traction control wires. As I recall there are three wires into that switch, and one is ground and another for the switch backlight, which is on the same circuit as the ABL. Check the "lighting and cosmetics" section here on Camaro5 and you should get details. |
12-26-2014, 11:01 PM | #12 |
Drives: 2012 2SS M6 CRT Join Date: Jun 2012
Series resistance divides the current over the total resistance of the loop. An LED is about 100 ohms at 2 volts (it takes less than 2 vdc to bias, or "turn on" an LED). Therefore, if you have a 300 ohm resistor in series with the LED, the LED will draw about 1/4 of the total current available, given the voltage drop across the 300 ohm doesn't go below bias voltage.
That being said, looking at the manufacturer's page, the kit is 12 volt powered, so unless there is a built in voltage based dimming circuit, they will be the same intensity at all times. The Body Control Module controls the dimmer circuit, and may be 5 or 12 volt. Dimming could be accomplished by voltage regulation or by Pulse Width Modulation. If it's PWM the kits may dim.
2012 2SS M6 CRT
SOLD! - - 1983 Berlinetta, 305HO, Comp 235 cam, shorties First real car: 1968 Malibu, '67 283, Canary yellow |
12-26-2014, 11:43 PM | #13 |
Banned
Drives: 2011 Chevy Camaro Join Date: Sep 2010
If you HAVE to make life hard and hook up to the sensor and HAVE to use 12v. Use a relay triggered by the 5v off the light sensor. There are easier ways but if you want to make your life harder use a relay.
12-26-2014, 11:51 PM | #14 |
V = I x R
or get an Arduino and write your own program to control lighting Typing fat fingered on my GS3...excuse any sfelling mitcakes
