Old 12-08-2009, 04:39 PM   #1
Betsi1214
Drives: 2LT RS Black/Black w/sunroof
Heated Seats with Remote Start
Are the heated seats supposed to come on when you use remote start? I thought I programmed this option but they do not come on. Do I need to take it in for repair?
Betsi1214 is offline   Reply With Quote
Old 12-08-2009, 05:12 PM   #2
5thGen
Drives: Black 2LT/RS, jeep Wrangler
if they are on when u shut the car off o think they would come on when you remote start
5thGen is offline   Reply With Quote
Old 12-08-2009, 06:00 PM   #3
BLKnCHRME09Deluxe
Banned
Drives: 2010 Camaro 2SSRS and a 09' Deluxe
Yea i noticed this also...I know the air comes on but don't feel heat in the seats. I have left them on while i turned off car and also have programmed what i think to be correct through the stereo system which says to heat seats on remote start. But still nothing. Maybe some help from someone?
BLKnCHRME09Deluxe is offline   Reply With Quote
Old 12-08-2009, 08:38 PM   #4
glambert1
HOMER
glambert1's Avatar
Drives: 2010 camaro 2LT RS SIM
I programmed mine to come on each time when i use the remote start and it does every time but when you get in the indicator lights will not be on but it will be working if yours doesn't do this it's broken go to dealer
....do it yourself and be proud when you brag about your mods...
glambert1 is offline   Reply With Quote
Old 12-10-2009, 02:52 PM   #5
BLKnCHRME09Deluxe
Banned
My car is at the dealer as we speak and they are looking into this feature..because my seats DO NOT turn on while in remote start. Has anybody else checked this feature...So far 2 NOT working and 1 saying it does
Old 12-10-2009, 03:17 PM   #6
kjd15
Finally!!
kjd15's Avatar
Drives: '10 2LT Summit white, '68 Camaro
I set them to come on with the remote start as well, and I thought they did not work because the indicator lights did not come on, but I'll have to test it again to see if they do in fact get warm without the light on.
-Karen
SW 2LT Ordered 9/30/09
November 28, 2009 - Delivered!!!
kjd15 is offline   Reply With Quote
Old 12-10-2009, 03:34 PM   #7
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Mine work.
I've found that if I don't turn the heated seats on before turning the car off, they won't be heating up when I get in the next time I use remote start.
I don't know if this is correct or not, but I know for a fact if I have the seats on when I turn off the car, if I use remote start the next time I get in, the seats are warm.
I believe there is already a thread on this
Old 12-10-2009, 03:57 PM   #8
BLKnCHRME09Deluxe
Banned
Originally Posted by CamaroSkooter View Post
Mine work.
Yes i found the other thread.. about 90% sayen they get NOTHING and theother 10% sayen they work ..
Old 12-10-2009, 04:15 PM   #9
kjd15
Finally!!
kjd15's Avatar
Do you guys get the indicator lights when the seats heat up with the remote start? That could be a key piece in why people think they aren't working (no light, no work)
I just assumed they weren't on because the light was not lit, so I just hit the button. But they very well could have been on. The car wasn't warming up for that long, maybe a minute or two.
-Karen
Old 12-10-2009, 06:07 PM   #10
BLKnCHRME09Deluxe
Banned
UPDATE....Just got back from dealer and heated seats only heat seat 20 degrees over outside temps per/chev tech advisors through GM
So i take it when seats are turned on as well as hot air just not enough to make a difference on your rear/behind/down low....atleast now i know...
Also was told a way to tell was to turn them on through auto start let it run and then when inside car feal your back seats then compare them to your front seats and there will be a difference....Good Luck.
Old 12-12-2009, 11:09 AM   #11
kjd15
Finally!!
kjd15's Avatar
Ok, I tested last night. Indicator lights do not light up, but seats do in fact get heated with the remote start when programmed to do so.
-Karen
Old 12-12-2009, 11:21 AM   #12
mghawk57
Drives: 2010 Camaro
Mine come on with the remote start when it was cooler out.Must be the default setting because I don't use the heated seats.My wife uses them (passenger seat) once in a while.Just My .02
mghawk57 is offline   Reply With Quote
Old 12-12-2009, 11:31 AM   #13
kjd15
Finally!!
kjd15's Avatar
It's not the default setting. I had to change mine to come on with the remote start.
-Karen
Old 12-12-2009, 08:26 PM   #14
acatlover13
Emerald Coast Camaros
acatlover13's Avatar
Drives: 2010 2SS/RS Camaro IOM/IO
Send a message via AIM to acatlover13 Send a message via Skype™ to acatlover13
I have no idea....haven't thought about it.....not used often in Florida!
ECC on Facebook
2010 Camaro SS/RS IOM, IO interior, Custom Striping, Razzi body kit
ADM CAI w/scoop/Dynatech Headers & Hi-Flow Cats/Solo Performance Exhaust, FTI 3600 Stall/Comp Cams custom grind cam/LS3 conversion/FAST 102 Intake
acatlover13 is offline   Reply With Quote
Remote start heated seats. Does it work? rodimus prime 5th Gen Camaro SS LS LT General Discussions 80 01-05-2010 01:44 PM
I'm lovin these heated seats!!! ROBBDOGG1986 5th Gen Camaro SS LS LT General Discussions 21 12-21-2009 06:53 PM
We need help with Electronics wiring diagrams 2SSRS@Gen5diy Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 12-13-2009 05:58 PM
Heated seats CJ1034 Interior Parts & Accessories 4 09-11-2009 10:12 AM
Remote Start l008com Camaro Price | Ordering | Tracking | Dealers Discussions 34 11-18-2008 03:19 PM
