Old 10-22-2018, 08:37 PM   #1
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Drag race hardware help
So, i want to use a TCI roll contol and run 26 tall tires in the back with no tire pressure monitors. What do i need to do so the car sensors dont freak out?
zz430camaro is offline   Reply With Quote
Old 10-26-2018, 02:23 AM   #2
NABeastRR
NABeastRR's Avatar
Drives: Camaro
Press the okay button
15 Camaro 2SS/RS
13.3@106 100% stock
12.0@114 VR-DRX/RCR manifold/BW stg2 TB/2"ARH w cats/3"Corsa extreme/Fasterproms tune/MT Street R
AGP TT build in progress
NABeastRR is offline   Reply With Quote
Old 10-28-2018, 05:01 PM   #3
KGoddard
KGoddard's Avatar
Drives: 2013 Camaro 2SS/RS
Remove fuse 40 and 43
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
KGoddard is offline   Reply With Quote
Old 10-28-2018, 05:45 PM   #4
zz430camaro
Drives: 2015 1LE
Thanks
Old 10-28-2018, 08:44 PM   #5
KGoddard
KGoddard's Avatar
It'll take away all traction control and assists. Will also take away your power steering. Would only take them out at the track.
Originally Posted by zz430camaro View Post
Thanks
Old 12-20-2018, 05:40 PM   #6
Vegas Bound
Drives: 2013 Sparkly Red One
I'll soon be running 28" front and 29.4" rear, thanks for the fuse numbers.
Vegas Bound is offline   Reply With Quote
Old 02-04-2019, 07:33 PM   #7
str8wick3d
Drives: 2011 Camaro SS
Hopefully fuse pull works for you. When I try that method it disables my ability to turn off traction control. Forces it it stay on. I know retarded.
str8wick3d is offline   Reply With Quote
Old 02-06-2019, 10:18 AM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
If the tires are 1.5" difference in height, the ABS will go nuts, so pull the fuses.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-06-2019, 02:30 PM   #9
Vegas Bound
How about 1.4" difference?
