Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > V6 Bolt-Ons & Tunes
Old 03-17-2019, 01:18 PM   #1
dynosteve
Dyno Tuner & Calibrator
dynosteve's Avatar
Drives: 2010 SS Camaro Turbo
Exclamation DeatschWerks DW400 Pump Module Direct Fit at RDP Store
RDP Store is Proud to Stock and Sell the DeatschWerks 10-15 Chevrolet Camaro V6/SS/ZL1 DW400 Pump Module and Filter Packages
DeatschWerks (DW) is taking it to the next level with the release of a complete fuel pump module solution for 5th gen Camaros - powered by the DW400 fuel pump.
The DW400 5th gen Camaro Module is a complete plug-n-play replacement for the OE unit. The module incorporates the DW400 pump which nearly doubles the flow output of the OE module and increases pressure capabilities to 120psi. This module also integrates seamlessly with the OE wiring harness, level sender, and feed lines. For those wanting a return-style fuel system, the module is easily convertible to -8AN feed and -6AN return. The module also utilizes a venturi fed surge bucket for consistent fueling at low tank levels and high G conditions.
The DW400 module deletes the restrictive OE cardboard fuel filter. A high flow in-line filter is recommended for use in its place. DW has designed a plug-n-play fuel filter kit utilizing their 10m dual stage stainless steel filter cartridge. The DW fuel filter kit is designed specifically for the 2010-15 Camaro with pre-cut -8AN CPE hose terminated in 3/8” EFI quick connects.
Complete plug-n-play high flow pump solution
Compatible with OE wiring harness, electronics, fuel lines, and level sender
Integrated check valve for easy cold starts
Flow-optimized internal plumbing
Powered by 415LPH DW400 Bosch pump
Compatible with pump gas, race fuel, and e85
Convertible to -8AN feed and -6AN return
Optional filter relocation kit available
https://rdpstore.com/p-12822-deatsch...-403-7001.aspx
For More Information and Special Forum Member Pricing PM us here or give us a call on 440 358 5500
RDP Store www.rdpstore.com
Shop 440 358 5500
Cell 440 251 8571
Kooks ARH Stainless Power ACT Aeroforce Kooks Husky AWE Gforce GForce SCT Edelbrock Whipple Magnuson Rotofab CAI Fore DSS Mishimoto Borla Magnaflow Corsa Trutrac EBC FIC
dynosteve is offline   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
