06-20-2019, 07:26 AM | #1 |
Drives: 2017 Camaro Join Date: Mar 2018
I need help "driving modes"
So all of a sudden an icon on my dash appeared. The letter "S." I've learned this stands for sports mode. I see I can also switch to Touring and Snow. As of last week none of these were on. There wasn't an icon. My steering felt completely different. How do I go back to how I had it before? Thanks for anyone's help.
06-20-2019, 07:36 AM | #2 |
Drives: 2017 Camaro RS Fiftieth Anniversary Join Date: Oct 2017
There's a button on the console behind the shifter that changes the modes. Press it and cycle through to the one you need. Normal mode is Tour. I accidentally tap it sometimes when putting something in the console or resting my hand near the shifter. The steering feel is definitely a result of the sport option.
06-20-2019, 08:19 AM | #3 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
Cycling through mine I don't notice any difference between Sport Mode and Touring Mode. Steering feel feels the same and I do not have the high performance exhaust so it sounds the same too. Are there differences that you can't feel? I have just a 1LT V6, manual, not as SS.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
06-20-2019, 08:42 AM | #4 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
I have a 1LT V6, and their is a difference in the steering for sure. Sport is stiffer
06-20-2019, 08:47 AM | #5 | |
Drives: 2016 F150 Join Date: May 2019
On my 2SS you can define in the drive mode setting in the headunit if you want the steering to be automatic, which changes with each drive mode or you can choose what you always want it to be. My guess is its set on one and doesnt change automatically. I keep my steering on tour and my exhaust in Track, but usually always drive in sport. |
06-20-2019, 08:57 AM | #6 |
Drives: 2021 C8, 2022 Camaro 2SS Join Date: Jul 2015
You might want to take a look at your 2017 Camaro owners manual, Driver Mode Controls, pages 236-241. Believe it will answer your questions.
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022 3400 1/25/2022 TPW 1/31 3800 2/15/2022 4300 2/19/2022 4B00 3/04/2022 4000 3/8/2022 Delivered 3/9/2022 ____________________________________ Order 6/01/2016 2017 2SS, NPP, 56R whls 3000 6/08/2016 3000 6/15/2016 TPW 7/18/2016 3400 7/7/2016 4200 7/25/2016 Delivered 7/28/2016 Sold May 2020 |
06-20-2019, 09:22 AM | #7 | |
Banned
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
I have exhaust locked into Track, steering locked into Sport, and generally drive in sport but sometimes toggle to Touring if the roads are really bad. I double tap the button when I start up to turn off the nannies and get into Stabilitrak Competitive Mode. I turn on rev matching with the paddle and I'm ready to go. |
06-20-2019, 11:51 AM | #8 |
It must be just the steering on our cars then. There is nothing else to change since they are more or less base.
06-20-2019, 12:43 PM | #9 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
I am not sure why your icons could be missing. Maybe it was a glitch. I have a 2SS but one of my friends has the 1SS and there is somethings that I have noticed that's different between the two. This could be same for the 1LT and 2LT as well. The 2SS when you switch thru the modes..it will change the stiffness of the steering wheel,exhaust sounds & accelerations and tighten the suspension. The 1SS just tighten the steering wheel & exhaust sounds and I believe the acceleration as well. I have mines setup up as Steering:Sport, Exhaust:Track, and Suspension: Based on auto mode selector meaning when I push the button it adapts. I dont think the suspension change on the LT models.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
06-20-2019, 12:46 PM | #10 |
I have an RS (V6) automatic. According to the vehicle documentation, Sport mode tightens the feel of the steering and changes the shift points on automatic. If you have Mag Ride Control it will be adjusted as well. Finally, if you have active exhaust it will open earlier an more often.
Snow/Ice mode adjust transmission to provide more traction. No Track mode on V6. Last edited by majik755; 06-21-2019 at 07:27 AM. |
06-20-2019, 04:04 PM | #11 |
The problem is I've owned the car for 2 years and "NEVER" seen the Touring or Sport icons on the dash before.... So you guys are saying one of these modes is required?
Does touring get the best gas mileage? |
06-20-2019, 05:24 PM | #12 | |
Drives: 2018 Camaro 1SS Join Date: May 2019
06-20-2019, 07:32 PM | #13 | |
Long hauler
The default is Tour, but you can switch through them and see if one was the one you had prior |
06-21-2019, 07:31 AM | #14 |
I'll have to check next time I'm in the car, but I don't recall always seeing the mode I'm in. It always shows when I change to a mode, but I think it may disappear after a while.
