Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-08-2020, 02:26 AM   #1
Camdenchester
Drives: bmw i8
Any ideas?
Top-Rated Green Light Laser Level for the Money: DEWALT DW088LG & DEWALT DW089LG*
Whether you often have commercial construction projects or make home masterpieces, a*green laser level*ensures the most precise layouts. In the past, people were only familiar with red laser levels. However, they are purchasing green ones because of their bright and easy-to-see beams. The operator’s eye and laser detector can conveniently detect green lines compared to red ones. Hence, you can use these for accomplishing both indoor and outdoor projects. On the other hand, the red beam laser is solely suitable for indoor tasks. Continue reading this post and get the*best laser level for the money.
✬✬✬ Important Site: LaserLevelHub - Best Green Laser Level Reviews
Without any further delay, read detailed reviews of the top-rated green laser level right now!
Editor’s Top Recommendation- DEWALT DW088LG Cross Line Laser Level
Introduction:*
The DEWALT DW088LG is a perfect addition to green laser levels on the market, incorporating the latest features at an affordable price. It generates horizontal and vertical laser lines that cross each other at 90-degree. This cross-line laser level runs on a 12-volt lithium-ion battery with up to eight hours runtime for accomplishing small to large-sized projects with ease. Furthermore, an IP65 rating ensures*green beam laser*remains protected from dust and water. Hence, you can use it without getting worried about the harsh worksite conditions.
The Most Dominant Features of DEWALT DW088LG:**
A self-leveling system is available to set the unit accurately within four degrees
With the Green Beam Technology, it projects horizontal and vertical lines that are four times more visible than red ones
Built-in magnetic bracket offers attachment to steel or other metal tracks with ease
1/4 and 5/8 inch mounting threads are available for placing it on the standard tripods
IP65 rating and over-molded housing make it a durable model, which can withstand harsh worksite conditions without getting any damage
Operating range is 100 feet that can extend up to 165 feet by using the Pulse Mode
The accuracy rate of this laser level is 1/8 inch at 30 feet
Why Did We Recommend The DEWALT DW088LG?*
We liked to recommend DEWALT DW088LG because of the following reasons.
Suitable for Various Applications:*
The DEWALT DW088LG generates bright horizontal and vertical laser lines, making it an ideal device for a wide range of leveling and square alignment applications. For instance, you can use it for installing cabinets, hanging arts on the walls, plumbing layouts, electrical works, custom painting jobs, and the list goes on. It projects a high visible 100 feet long laser line that further extends up to 165 feet by turning on pulse mode.
Accurate Leveling Layouts:*
We also loved this model for higher precision measurements than many other ordinary choices available on the market at the same price tag. This green line laser offers an accuracy rate of 1/8 inch at every 30 feet. A self-leveling system automatically levels the unit within four degrees. Therefore, you can start your work immediately after placing it on a tripod or any other flat surface. This system also ensures that you will achieve the most accurate leveling layouts for completing your projects effectively and efficiently.
Mounting Choices and Durability:*
With the built-in magnetic base, one can mount it on steel or other metal surfaces whenever needed. However, it also has 1/4 and 5/8 inches mounting threads for installing on the standard tripods. Furthermore, over-molded housing and IP65 rating make it the*best green laser level*for those who work at dusty and rainy sites.
❆❆❆ Find More Information: Check This Helpful Guide
Best Professional Model: DEWALT DW089LG 3 X 360 Green Laser Level
Introduction:*
The DEWALT DW089LG is an upgraded version of the previous model, which can take your performance to the next level. If you want to use one for covering the entire area, buy this tool instead of any other option. It generates three 360-degree laser lines for providing a leveling layout on the walls, ceilings, and floors. Furthermore, you can use two vertical or horizontal lines simultaneously and individually according to your project requirements. It offers a 100 feet range that extends up to 165 by using a receiver and selecting the Pulse Mode. You can use this*360 green laser level*for achieving the most accurate leveling and squaring layouts because of its 1/8 inch accuracy at 33 feet.
What Are the Advantages of Purchasing DEWALT DW089LG?*
The DEWALT DW089LG offers the following benefits, which forced us to select this*green beam laser level*from different available options.
Full Layouts All Around the Working Area:*
The DEWALT DW089LG is the best green laser level for those who want to achieve full leveling or squaring layouts around the room. With three 360-degree lines, you can cover the walls, floor, and ceiling without using any other leveling device. Furthermore, easy operating buttons on the panel will allow you to project all of these beams separately or together. Hence, this versatile model makes complicated projects much easier than ever before.
Suitable for Indoor and Outdoor Applications:*
It also includes the latest Green Beam Technology to provide more visible lines than other ordinary models. Hence, you can use it for small indoor projects for a wide range of large tasks. Its operating range is 100 feet, which can increase up to 165 feet with the Pulse Mode. However, you will have to use a receiver before taking benefits from this function. This system not only extends its range but also enhances visibility and accuracy rate.
High Accuracy and Long-Lasting Performance:*
The accuracy rate of this*green line laser level*is 1/8 inch at 33 feet. Therefore, you can use it for accomplishing your constructions with precision. Over-molded manufacturing design enables it to withstand hazardous worksite conditions for up to many years. IP65 rating ensures it can resist debris and splashes of water.* * **
✩✩✩ See This Page: How to Buy Green Laser Level - Best Green Laser Level Reviews
Automatic Leveling System and Mounting Choices:*
It incorporates a pendulum system that atomically levels the device within four degrees. Furthermore, this system also protects internal mechanical parts when transporting this laser level. An integrated magnetic bracket is available on the base to attach it to metal and steel surfaces. Furthermore, two screw threads are also present for mounting on a tripod.
Final Thoughts:*
Indeed, DEWALT is one of the most trusted brands for offering the most accurate and high-quality laser levels on the market. Hence, you can rely on its*green light laser level*models for accomplishing your upcoming projects.
Camdenchester is offline   Reply With Quote
Old 07-08-2020, 05:06 AM   #2
'10CamaroDude
Drives: 2010 Camaro LS
I had one of those tent-like bike ports, $150.00 or so. Put it in my yard, and
put the bike in it. Never got any water inside.
'10CamaroDude is offline   Reply With Quote
Old 07-09-2020, 02:22 AM   #3
Camaro__ss
Drives: 2013 L99
Plastic shed from Lowe’s.
Camaro__ss is offline   Reply With Quote
Old 07-09-2020, 10:28 AM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
This and some bungie cords.
https://www.uline.com/Product/Detail...E&gclsrc=aw.ds
Vegas Bound is offline   Reply With Quote
Old 07-10-2020, 10:52 AM   #5
Level300
Drives: 2015 Black rs/ss/1le
See if a motorcycle shop near you has a shipping crate they are going to throw away. You’re halfway there if you start with one of those. But don’t tell them what its for, they’ll probably charge you a couple of hundred dollars For it. Then hunt around for a used tent to use as a cover?
Level300 is offline   Reply With Quote
Old 08-08-2020, 08:42 AM   #6
Pete G
Pete G's Avatar
Drives: 2015 SS 1LE
It sounds to me like he is having a problem with the area flooding if he is talking about a platform.
Pete G is offline   Reply With Quote
Old 08-08-2020, 09:31 AM   #7
Cristjw
Cristjw's Avatar
Drives: 2014 Camaro RS 2LT convertible
Plastic pallets. https://www.phsinc.com/pallet/plastic-pallets/
According to your profile you have an I8 Beamer. Build a cheap ramp at the front of the I8 and nice running start on the bike would get you right on top of the car to keep the bike dry. It’s basically a mobile plastic pallet for battery and component storage anyway. You could try from the back too but you’ll need a little taller ramp.
Welcome to the forums.
Cristjw is offline   Reply With Quote
