#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 02-14-2016, 09:51 PM   #1
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
How To Hardwire your radar detector by Tejesh83
I take absolutely NO CREDIT for this... Just saving some time and effort for Tejesh83 and moderators. Main thread can be found HERE
Originally Posted by tejesh83 View Post
I hard wired my Escort Max 2 Radar Detector this morning. Here's a quick guide. Special thanks to forum member 2SSRS@Gen5diy for finding a switched 12V source in the console.
Now for the install:
  1. Pry the corners of the console. I used a plastic putty knife and a rag over the mirror to avoid damaging any trim.
  2. Next, pry the center of the console. The console clips should now be loose, so give it a firm tug and the console should free up. Disconnect all wires and set the console aside.
  3. Route your power cable from the windshield, through the headliner, and grab it from the console opening. You can buy a fused mirror tap to save time (http://www.amazon.com/gp/product/B00...f_rd_i=desktop). I made my own out of an old telephone cord and a soldering iron.
  4. On the back of the plug that feeds the airbag light, tap the Purple/White (+12V) and Black (-GND) wires. Now's a good time to check the wiring with a meter and confirm your radar powers up. Make sure you start the car for your testing. I learned the hard way this wouldn't turn on with accessory power =)
  5. Press the wire taps firmly into back of the plug and use a zip tie and electrical tape to secure it in place.
Finished results:
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 02-15-2016, 02:22 PM   #2
jimmypop13
Drives: 2016 camaro ss
The tapping a wire part is not explained at all. I need to know exactly what you did with the wires from the radar detector. It sounds like they were stripped and just crammed in some holes with the other wires
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 02-15-2016, 03:00 PM   #3
MGD
MGD's Avatar
Drives: 16 Camaro SS
Have a look at this. I would T-Tap the wires instead of pushing them in the connector.
the Purple/White is 12 switched and the black is ground. Did this for my dash Cam.
http://www.camaro6.com/forums/showpo...1&postcount=17
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 02-17-2016, 05:28 PM   #4
ManOfSteel
Drives: 2016 2LT/RS Garnet Red Tintcoat Cam
Well have to give this a try, I was going to run it down to the kicker panel
Sent from my Supermaro
ManOfSteel is offline   Reply With Quote
Old 02-18-2016, 07:08 AM   #5
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
It looks like you have to cut the cigarette lighter plug off to hardwire it. Is that correct?
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 02-18-2016, 08:03 PM   #6
tejesh83
Drives: 2016 Camaro 2SS
no, you can just use a standard telephone cord. the two middle pins, normally green and red on most cords, can be used for the taps.
2016 2SS - Summit White - MT - NPP - MRC - NAV
tejesh83 is offline   Reply With Quote
Old 02-18-2016, 10:22 PM   #7
ParisTNDude
I didn't realize the connecter was a telephone jack. Now that I can do. The cord that comes with my unit is just too expensive to cobble up, plus I use it on multiple cars.
Great DIY...thanks for posting.
Old 02-22-2016, 02:06 PM   #8
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
This worked perfectly I used some wiretaps from Lowes.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 02-26-2016, 07:08 AM   #9
pcrage_2
pcrage_2's Avatar
Drives: 2018 2SS-1LE
ok i gave this a shot but my plugs were all REALLY tight and i didnt want to get too agressive and break something. so, what is the key to unplugging the 3 connectors? on the grey ones towards the back of the car, do you need to push a release tab that i am missing? on the single plug towards the windshield, i am guessing releasing that one has something to do with the red clip, do i need to pop that up with a small screwdriver or something?
i have done many many radar detectors, and wow this is one a real challenge!
thanks for any advice!
2018 2SS-1LE
Silver Ice Metallic
CAI Intake
Mishimoto catch can
Vitesse throttle controller
pcrage_2 is offline   Reply With Quote
Old 02-26-2016, 07:29 AM   #10
tejesh83
Yes, they all have release clips.
For the gray ones, you could use a tiny screw driver or a pin to release the tabs (its on the right or left end) For the white plug towards the windshield, see the 4th pictures in the original post for zoom in on the connector. You'll actually want to depress the white center (not red) to release the clip. For this one, I used a slightly bigger screwdriver, placed it on the white part of the plug, in the center, pressed, and twisted it against the socket and it came right out.
Old 02-26-2016, 08:19 AM   #11
pcrage_2
pcrage_2's Avatar
awesome, thanks for clarifying. just to make sure, you press in these spots and pull? hope you don't mind me using your pics.
a picture is worth a thousand words (and possibly a thousand posts!).
2018 2SS-1LE
Silver Ice Metallic
CAI Intake
Mishimoto catch can
Old 02-26-2016, 11:20 AM   #12
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
If i may, the white connector has a red part at the top of the pic, that needs to come out 1/16" first then push the rest of that white tap down and pull at the same time it will come out.
Old 02-26-2016, 03:24 PM   #13
tejesh83
Oops, I didn't realize that. Good catch! Thanks again for posting pics of the console and which wires to tap. I wouldn't of figured it out without your original post.
You got it, those are the right spots. But 2SSRS@Gen5diy corrected me, you need to pull out the red tab 1/16" first. I didn't realize when I was taking mine apart.
Old 02-26-2016, 03:52 PM   #14
BigEnos
Planning stages...
Drives: 1995 Z28,2014 Ford Focus ST
Thanks for the explainer. On a related note I noticed you are using a sticky cup. Is there room to use a blendmount, or will the detector sit too low and be in a sightline of the driver?
BigEnos is offline   Reply With Quote
