Old 11-21-2017, 08:51 PM   #1
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Flowtie made and mounted to stock SS Grill
Pics in this Order (sorry for low resolution, transferred from cell phone via newer Yahoo mail and it made them JFIF files which the Forum won't allow, so had to convert to png) :
1. Started with stock SS Bowtie that arrives on car from factory. Removed gold Chevy emblem from inside the chrome housing. And cut the perimeter/chrome.
2. Cut the black grill backing plate that the Bowtie was mounted to - in to a Chevy emblem shape and filed edges.
3. Painted two threaded cubes (so they would not rust) and used them as fasteners on the studs I attached to back of homemade Flowtie.
4. Installed homemade Flowtie (just like original the Chevy engineer created for the 1st 2014 Z28).
5. When I want to see the Gold Bling Chevy shield, I can just pop it back in the center of the Flowtie to return it to the stock Bowtie!
6. And now the radiator can get a bigger blast of cool air via the Flowtie as shown in the diagram.
(Using this design the inner gold shield can quickly be popped in or out ... Flowtie or Bowtie switched back and forth in seconds)
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 11-21-2017, 11:06 PM   #2
DagoCountyGee
DagoCountyGee's Avatar
Drives: '15 SS
Dope!!
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
DagoCountyGee is offline   Reply With Quote
Old 11-21-2017, 11:49 PM   #3
hammdo
'It's an experiment'
hammdo's Avatar
Great job!
Here is mine on an 11:
-Don
747 RWHP 794 RWTQ
Old 11-22-2017, 06:18 AM   #4
GRNFLSH
GRNFLSH's Avatar
Drives: 2015 Camaro 2SS Green Flash Edition
ron123, thanks for the write up, I’m adding this to my winter project list. Question, how did you attach the mounting studs to the back of the chrome bezel?
Kooks stepped headers & Solo XL Cat-back
ADM CAI w/race scoop & Rotofab w/w relo
GPI VVT SS1 cam and CNC ported heads milled .30
BTR .660 springs, Straub solid bushing trunions
GPI rod-mod intake with I-M heat sheild
Circle D 258mm Pro single disc 3700 rpm stall converter
169F thermostat & manual fan switch
Tuned by Ryno at GPI - 455 RWHP / 416 lb-ft
GRNFLSH is offline   Reply With Quote
Old 11-22-2017, 09:04 AM   #5
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Your welcome.
Used two ~4x32 screws 3/4" long or less. Smaller diameter the better to hide it.
Added small flat nut turned down all the way to head of the screw giving larger surface area to anchor.
Cleaned chrome on back with rubbing alcohol
Then, right at edge of Bowtie where bevel is, put a big sloping blob of Silicone Rubber and let cure for 24 hours. Same stuff they used to bond the space shuttle tiles on. If you carefully fill in on the three sides it is extremely strong to hold the stud on. Checked from many angles at front to make sure the silicone rubber is not visible - and adjusted as needed.
Good to make sure the studs are verticle in the same plane that you will be sliding it back on to the grill so they go in the grill mount holes properly later.
Around the perimeter of the Bowtie I used 1/8" wide 3M emblem tape that I cut myself (not really needed but helped hold it in exact position as I was putting the block nut on the 2 studs).
This takes hours to do, did not want to make mistakes so I took each step super slow.
Old 11-22-2017, 10:01 AM   #6
Spurshot
Drives: 2014 2SS blue
Spurshot is offline   Reply With Quote
Old 11-22-2017, 12:01 PM   #7
oldschoolkat
oldschoolkat's Avatar
Drives: 2013 SS Camaro
Fyi...u can just attach the images when you post...no need to convert or upload images anywhere else...great mod 👍🏾
Sent from my SM-N920P using Tapatalk
oldschoolkat is offline   Reply With Quote
Old 11-22-2017, 07:44 PM   #8
White_Camaro
White_Camaro's Avatar
Drives: Camaro SS
I did the same thing except I put a z28 grill with the flow tie on already
White_Camaro is offline   Reply With Quote
Old 11-22-2017, 08:12 PM   #9
gringo
gringo's Avatar
Drives: Camaro V6
I wouldn't want to hack up my original grill to do this mod. Interesting nevertheless though!
gringo is offline   Reply With Quote
Old 11-22-2017, 08:32 PM   #10
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
That's just too cool! Nice job man.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 11-23-2017, 05:35 PM   #11
ron123
ron123's Avatar
Drives: 2014 2SS/RS
Originally Posted by gringo View Post
I wouldn't want to hack up my 1st original grill to do this mod. Interesting nevertheless though!
My thoughts exactly. Take a look at last grill picture in the series of my original post. The gold shield is dropped back in to the Chrome and looks exactly like it arrived from factory. No sign of any grill mod no matter what angle you look at it from. One second to switch it back and forth. Undetectable stealth mod. Even the most expert vehicle appraiser would never know.
Patent Pending. lol
Old 06-20-2018, 06:51 AM   #12
Gotit4cheap16
Drives: Victory Red
Originally Posted by hammdo View Post
Great job!
-Don
How did you make yours don?
Gotit4cheap16 is offline   Reply With Quote
Old 06-20-2018, 08:36 AM   #13
hammdo
hammdo's Avatar
https://www.camaro5.com/forums/showp...postcount=2066
-Don
747 RWHP 794 RWTQ
Old 06-20-2018, 08:40 AM   #14
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 Crystal Red 2LT/RS
Those look awesome, great job!!
mr_honez is offline   Reply With Quote
