Old 08-09-2020, 10:55 AM   #1
bucklwi1
bucklwi1's Avatar
Drives: Chevrolet Malibu
OEM GM Factory 1LE Splitter
I have a GM 1LE splitter, brand new in box. I only opened the box to take pictures. It came with my 2013 1LE but was never installed. I no longer have the car.
$500, local pickup only.
I am in Raynham, Massachusetts.
bucklwi1 is offline   Reply With Quote
Old 08-09-2020, 12:53 PM   #2
bucklwi1
bucklwi1's Avatar
Here are some pics
Old 08-09-2020, 11:21 PM   #3
tchaney86
Drives: 2013 Camaro 1LE
Youre missing a lot of parts to this Fascia package to ask for $600. You only have the front splitter right?
tchaney86 is offline   Reply With Quote
Old 08-10-2020, 12:08 AM   #4
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
GM Parts Direct
Fascia Pkg - GM (22950575)
List Price: $1,059.28
You Save: $369.69 (35% off)
Sale Price: $689.59
Core Charge: $75.00
ADD TO CART
Buick, GMC, Cadillac, Hummer, Saturn, Oldsmobile, Pontiac, Chevrolet Parts
Manufacturer: GM
Part Number: 22950575
Part: Fascia Pkg
Replaces: 23109510
FasNuf is online now   Reply With Quote
Old 08-12-2020, 08:45 AM   #5
Plastamasta
Plastamasta's Avatar
Drives: 2011 Synergy Green 2SS/RS
What is bottom package in plastic ?
Plastamasta is offline   Reply With Quote
Old 08-12-2020, 02:57 PM   #6
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Let me know if you change your mind about shipping.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
Old 08-12-2020, 04:31 PM   #7
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Looks like the mounting kit for the front and sides.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 08-13-2020, 04:16 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So the splitter will fit on 2010-2013’s SS’s models an if I remember correctly the RS fascia on a V6 car will also work. A base V6 it will not fit.
Orange Krush II
Old 08-13-2020, 07:50 AM   #9
rviper24
rviper24's Avatar
Drives: 2013 Camaro SS 6-Speed
Not to bust on your post but cant you get the same thing on ebay for $100?
2013 Camaro 1SS 6-Speed LS3
All stock.. For now...
rviper24 is offline   Reply With Quote
Old 08-13-2020, 11:41 AM   #10
FasNuf
FasNuf's Avatar
What Ive seen on ebay is usually their stuff is garbage. For instance, There was a rear spoiler that looked good that I wanted. I noticed there were no mounting bolts. When I told the seller that my car sees speeds over 150 mph, he told me his wouldn't be able to stay on the car. LOL. obviously. For the most part, you get what you pay for in the parts world.
Old 08-13-2020, 04:38 PM   #11
Plastamasta
What’s in the other packages .might be interested and I’m local
Any other pics
Old 08-13-2020, 09:36 PM   #12
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The other bags contain the mounting clips and an hardware these OEM 1LE splitters are hard to come buy even back in 2013-14 and they were 400-500 then,I think a more reasonable price would be 350 shipped.
Orange Krush II
Old 08-18-2020, 09:08 PM   #13
Plastamasta
Kevin Silvia 508 324 5505
PM me I’d like to check it out
Old 08-19-2020, 04:53 AM   #14
ZWA SS
BowtieBelle's SS
ZWA SS's Avatar
Drives: 2010 Camaro SS
Message me if you will split the mounting hardware and splitter.
ZWA SS is offline   Reply With Quote
